Problem with LRP Sphere TC
Has anyone had a problem with a LRP Sphere TC, it is like the speedy has auto brake on, however the speedy has the inital brake and the auto brake set on "0".
I tried the motor on a older sphere speedy I have and it works ok so it must be the speedy.
Have set the transmitter and the speedy up more than once, with no change.
if yo turn the pinion at neutral throttle it has drag, you turn the power off and it has none.
Regards
Gary
Regards
Gary
I have heard that this is an issue with the ESC, and you will have to send it back to LRP.
I have noticed the same thing in my XXX4G+. I have the 2007 edition.
I thought I was just imagining things but this is good to know.
So, this is a known problem with the Sphere huh?
