1/8 novak HV vs feigao 9xl
#17
ok
ok, so hear is my final desision, let me know if anything should be changed.
Losi 8ight-t pro kit with Rcprouductdesings convirsion
castle phoenix-85 esc
1 fan for esc
castle creations 2-6s BEC
neu 1515/1.5d/f
4s 14.8v 5000mha battery
46tooth plastic spur
12tooth pinion
and im runing on a medium sized dusty track
1 fan for esc
neu 1515/1.5d/f
12tooth pinion
#18
You want a Mamba Max... in place of the Phoenix85.
Without knowing what you are doing, you may not even get the Phoenix to work at with a car radio. And if you do, you will need to run mechanical brakes.
Besides, ask Castle.... it's not built to take car abuse either.
#19
ok
well with the mambamax, wont it overheat real fast, im using a 4s with that 1/8th scale truck/motor
#20
No... it's what most of us have been using. It's been an incredible little controller, better than many @3-4x the price.
It's not indestructible, but it's proven tougher than most.
#21
Wow
WEEE you got me all exited! what temps should i quit runing at and what are the runtimes im looking for aprox?
#22
bec
i wont need a BEC right?
#23
1 fan for esc
neu 1515/1.5d/f
12tooth pinion
1 fan for esc
neu 1515/1.5d/f
12tooth pinion
hey guys does anyone know if the phoenix 85HV will run in an onroad car, and how to set it up..
#24
phoenix 85HV will run in car, but no reverse. I would go with mamba max instead.
#25
if staying 4s or less,try the hobbywing 80 amp 1/8 controller.it is big,which should help it last.you dont need a seperate bec for it.you will with the mamba max for sure.the hobby wing is only like 80 bucks on ebay or maybe rc-monster.this is the beauty of conversions,there are so many choices it'll make your head swim...
