Old 07-28-2003, 06:45 AM   #1
Default 9.6v Battery in a 7.2 volt car?
Hey, I admit it, I'm a newb on this forum, but I didn't know where else to turn for my question.
I took a quick glance around, didn't see my question asked, my apologies if you get it every two weeks....I know how anoying that is from the computer Overclockers forum I go to.
Anyways, I have this old 9.6v AA Ni-Cad battery. I have a car I'm modding and it uses a 7.2 volt battery with sub-C's. Same connector on both. Is it ok to "overvolt" it with the 9.6 volt battery? And, I have a kind of crazy plan to use a connector from an old car to have dual batteries in series. Can the increased current cause any damage? And what if I used two different voltage batts? (The 7.2 and the 9.6)
Really sorry for the long, overly complex, probably overly posted by others post. Thanks in advance guys!
Fuzzbeaner is offline   Reply With Quote
Old 07-28-2003, 08:34 AM   #2
traxxasdude's Avatar
what type of esc are you using? If your using one that can handle the equivelent of 9 cells then it will work.
traxxasdude is offline   Reply With Quote
Old 07-28-2003, 10:25 AM   #3
fatdoggy's Avatar
R/C Tech Charter Subscriber
Don't run AA's in high drain conditions, they will overheat very quickly.
fatdoggy is offline   Reply With Quote
Old 07-28-2003, 10:57 AM   #4
I'm not sure what the speed controller is - I'll explain.
I'm using an old Nikko Thor 4wd I found in my attic. It was busted up, but I had this other Nikko with interchangable parts. So I fixed it, and then stripped it up extraneous crap, only the battery didn't work.
So I have NO clue what the electronics and innards are, sorry. :-/
As for the heating up thing....well, if they'll get too hot I guess I shouldn't use them anyways. :-p Anything hotter then the 7.2 I'm running on now would be at boiling point.
12 Volt starter battery Xray69 R/C Items: For Sale/Trade 5 05-19-2008 07:37 PM
7.2 volt battery and charger xtmfreak55 R/C Items: For Sale/Trade 0 07-09-2006 06:57 PM
LIPO BATTERY (11.1) VOLT LOSIMANJRXS R/C Items: For Sale/Trade 12 04-27-2006 06:22 PM
400 VOLT BATTERY ZAPPER FOR SALE THIS IS NOT A TOY BCOLEMAN R/C Items: For Sale/Trade 2 11-06-2005 09:33 AM
using 9 volt battery ??? IBRCing Nitro On-Road 2 06-08-2005 09:04 AM
SEO by vBSEO 3.5.0
