Old 04-28-2008, 02:53 PM   #1
Default What is cogging?
Sorry about stoopid question...
first brushless system..
leigh18 is offline   Reply With Quote
Old 04-28-2008, 03:01 PM   #2
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Wat brushless u running. Not sure, but usually at low RPM's the motor will hessitate hard to explain. We found it to usually be a low voltage condition.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 04-28-2008, 03:22 PM   #3
cm367700's Avatar
Send a message via AIM to cm367700
it's when your car starts to jerk when accelerating
(='.'=) This is Bunny. Copy and paste bunny into
("')_("') your signature to help him gain world domination!!!!!!!
cm367700 is offline   Reply With Quote
Old 04-28-2008, 03:32 PM   #4
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
As far as it's my understanding, cogging in a BL motor happens when the ESC loses track of the rotor. When there's no load on the motor, as each pair of armature stacks in the can fires the rotor follows and life's good. But if enough of a load is placed on the rotor (i.e., hard acceleration under the weight of the car) that it slows down, there's a chance that the stack's firing can get far enough ahead of the rotor that the easiest path for the rotor to take is backwards. Of course, this happens so fast all you get is this strange buzz and the motor tripping flat on its face instead of running.
That's the big advantage to sensored systems, the sensor tells the ESC where the rotor is so if it starts to fall behind, the ESC can automatically slow down the firing sequence & let the rotor catch up. Sensorless systems, the ESC just keeps sending power 'round and 'round the can regardless of the rotor's position.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Cogging with Brushless d4man Electric Off-Road 8 03-12-2008 08:17 PM
Mamba Max Cogging mattnin Electric On-Road 42 05-10-2007 07:47 AM
novak GTB cogging ff01 Electric On-Road 7 05-09-2007 07:33 PM
Bad Brushless Cogging? Litespeed Australian Racing 10 02-17-2007 03:11 AM
Cogging help? knucklebusta Electric Off-Road 5 12-17-2005 08:04 PM
SEO by vBSEO 3.5.0
