Lipo in a B44???
#16
I thought about installing then to the inside as you did but was worried about a short, carbon fiber does conduct electricity
#18
hey guys heres another question what motors do u run cuz i have the LRp 7.5 and it overheats like crazy to the point where i think my pack is dead.... then i peak my pack and it goes to like 3000 and its a 4600... i had the motor at like 180... i have tried smaller pinion sizes and everything what motor should i run
#19
I am running the same motor w/ 19t (indoors) and dont have any heat issues
even after 10 minutes of runtime w/ a maxamps 4000mah lipo.
#20
im running a 5.5 geared at a 18 tooth (indoors) and no problems what so ever.
#21
#22
#23
6.5/GTB with a 16/84 and temps are around 150 esc and 120 motor.
#24
For you guys running MaxAmps- How did you mount the LiPo at the carbon fiber / batt plate?
Pics Please.
Pics Please.
#25
#27
I did this yesterday but went a little further. Since the posts are too short now, I removed the bottom tray for now and placed some double sided tape on the bottom as well. Flipped the strap and D/S tape as well on that. Got some longer 4/40 screws and loctite. WEll, we'll see if this holds up. Hate to have the batteries move during a race. I might make my own plate using some C/F pieces I have.
#28
Do you have a sintered rotor or are you using the standard one that came with it? If you have repeatedly heated the motor past 180, its definitely time for a new rotor. Had a friend with the original reedy 6.5 motor and he couldn't keep it cold without gearing it to the floor in his 4 wheel. Picked up a new lrp sintered rotor and ballbearings and it hasn't gotten over 130 since.
#30
