Old 07-11-2003, 03:48 PM   #1
Send a message via AIM to DraKhen99
Default T3 Gearing Question
Ok, so I'm not new to R/C, but I'm new to lower-winds-than-stock and mod motors, as well as gearing.
I have an Associated T3, and I'm getting ready to put an EPIC 19t Outlaw Pro mod motor in it. What final drive ratio should I look for in order to not gear it too low [or too high]?
Also, I believe I read somewhere that the tranny's gear ratio is 2.4. I this correct?
I know the extra strain of pushing around the T3 will heat the motor up, so I'm going for a mid-range gearing, not too much acceleration or top speed.
The T3 is pretty much going to be run in low grass, asphalt, and maybe some dirt, but rarely.
Thanks for your help!
DraKhen99 is offline   Reply With Quote
Old 07-15-2003, 02:55 PM   #2
Send a message via AIM to MyMonkey
Well, the final drive ratio thing is lost on me; however, I race with a Team Associated driver and his statement to me on gearing was this: "Always use the stock spur and a 17,18 or 19 tooth inion." NO matter what. That is what he does and seems fine for him. So I would start with 17 and go from there.
MyMonkey is offline   Reply With Quote
Old 07-18-2003, 07:36 AM   #3
Well, I dropped my EPIC Outlaw Pro into my T3 last nite, with a Novak Rooster ESC.
I didn't count teeth on the spur, but I am guessing it is still the stock # of teeth [I bought the truck from a friend of mine, and haven't had the chance to ask him about the spur yet].
The pinion teeth I counted, and came up with 22... which is too high. The FDR is too low with a 22 tooth, so I am going to get some more pinions today, probably 17 to 21 teeth, to go with the 22. I'll probably start with a 20 tooth pinion, since the gearing that was on there was only somewhat low.
XXX-S Gearing Question TeamPink91 Electric On-Road 7 05-15-2010 08:55 PM
Gearing Question jeffbhhs Electric On-Road 3 06-12-2008 04:26 PM
AE 12L gearing question. MrZero Georgia Racing 4 11-06-2007 09:42 AM
Gearing question Sal Amato Electric On-Road 1 09-09-2006 12:01 PM
Another gearing question Elk666 Electric On-Road 6 05-02-2003 08:50 AM
SEO by vBSEO 3.5.0
