What's your 1/8th electric selections?
#62
I must agree. This is a great thread!
Looks like a lot of people are running the Mamba Monster Max. I have been recommended to stay away from the MMM from local racers that didnt have good luck with it but I read that a Version 3 just came out. I am debating between the following ESC/motor combos:
1. MMM/NEU 1512 2.5D
2. 1/8 scale Losi Xcelorin/1700Kv combo.
3. MMM/Hacker E50 mot0r
Any insight would be much appreciated.
Chirag
Chirag
#63
Hey, I have added #12 Pinion and spur gear tooth. Please re-post if you don't mind!!!
1. <Car>
2. <Motor>
3. <Speed controller>
4. <Lipo Battery>
5. <Charger>
6. <Conversion Kit>
7. <Cooling Fan>
8. <Likes of your setup>
9. <Dislikes of your setup>
10. <Description on your motor performance>
11. <Battery Life>
12. <Pinion/Spur tooth>
1. <Car>
2. <Motor>
4. <Lipo Battery>
5. <Charger>
6. <Conversion Kit>
7. <Cooling Fan>
11. <Battery Life>
#64
Just finished
I decided to go a temporary route. I am waiting for the Tekin R8 ESC.
Until then I am running the following:
1. Losi 8ight buggy
2. Losi 8ight E conversion kit
3. Losi 5000mah 14.8v battery
4. Tekin R1 ESC with two 25v 1000uf capacitors
5. Losi 2000mah, 7.4v lipo receiver pack
6. Medusa 36 60 2000kv motor with factory heat-sink.
I am running the 15t mod 1 pinion that came with the
losi kit but have a 13t long shank pinion on order.
Test run was successful. Fast,, wheelies, motor barely got warm in 10 minutes. ESC was at 5 LED's. No fan, but running 8ight E body that has four holes from the factory.
What pinion do you guys recommend. How many LED lights do you think is acceptable on the R1? Is a fan recommended?
1. Losi 8ight buggy
#65
1. <Car> Associated RC8
2. <Motor> Neu 1512/2.5/D/F
3. <Speed controller> Mamba Max (unmodified) 1 fan
4. <Lipo Battery> ThunderPower 4s 25c 5000mah, Trakpower 4s 25c 4900mah
5. <Charger> ThunderPower 610c
6. <Conversion Kit> RCPD Conversion Kit w/Integrated Battery Tray
7. <Cooling Fan> 1 available from RC Tech (looking for link...)
8. <Likes of your setup> Once it gets up to operating temperature (160-165*) it doesn't rise any further, pack after battery pack. Well designed and OEM looking.
9. <Dislikes of your setup> It would be nice not to depend on a $2 to keep the ESC cool!
10. <Description on your motor performance> Linear feeling power, very controllable, same speed as a "tuned" nitro engine and pipe.
11. <Battery Life> 20 minutes on a large track, medium traction, big jumps, elevation changes
12. <Gear Ratio> 46T Plastic Kyosho Spur Gear, 19T Robinson Pinion
#66
Here is my planned setup that I will be running soon. Still some questions.
1. <Car> XRay XB808
2. <Motor> Speed Passion Silver Arrow 6.5
3. <Speed controller> Speed Passion Silver Arrow ESC
4. <Lipo Battery> Zippy-R 4s 4800
5. <Charger> Dont know yet.
6. <Conversion Kit> RCM XB808 Motor Mount
7. <Cooling Fan> Dont know yet
8. <Likes of your setup> Hopefully I like everything
9. <Dislikes of your setup> Hopefully I dis-like nothing
10. <Description on your motor performance> Dont know yet
11. <Battery Life> Hopefully it lasts atleast 15 minutes
12. <Pinion/Spur tooth> Not sure yet.
1. <Car> XRay XB808
#67
1. <Car> Xray XB8
2. <Motor> Novak 6.5 HV
3. <Speed controller> Novak HV pro
4. <Lipo Battery> (2) Orion 4800 Lipo 7.4v (2) Duratrax 5400 Lipo 7.4v
5. <Charger> FMA Direct Scorpion2 and Triton
6. <Conversion Kit> Novak XB8 conversion
7. <Cooling Fan> Novak, 1 on SC, 1 on Motor
8. <Likes of your setup> Great acceleration, runs cool, low maintenance
9. <Dislikes of your setup> Pushes in corner, miss brake bias
10. <Description on your motor performance> Couldn't ask for more
11. <Battery Life> 15-20 min depending on batteries
12. <Pinion/Spur tooth> 11/48
#68
1. MBX6
2. Medusa 36-60-2K
3. MMMV3
4. 5S A123 (for practice & heats) Flightpower 5SLipo 3850mAh, MaxAmps 5S 5000 (Lipos for racing)
5. Hyperion 610i & 1210i
6. RCPD MBX5 conversion with a modified RCPD MBX5 ultimate battery tray.
7. Just the one in the MMMV3
8. Lite setup, just powers past nitros at the end of the straight.
9. N.A.
10. great torque & just a little faster than nitro
11. A123=7 to 8 min, Lipo 3850= 13 to 16 min, Lipo 5000= 16 to 20 min
12. 46/16 or 17
2. Medusa 36-60-2K
3. MMMV3
9. N.A.
12. 46/16 or 17
#69
UPDATE:
1. <Car> Mugen MBX6
2. <Motor> Either NEU 1512 1.5Y
3. <Speed controller> MMM V3
4. <Lipo Battery> ZIPPY-H 5s 3300mah and 4000mah
5. <Charger> Hyperion 610i dual
6. <Conversion Kit> RC Monster
7. <Cooling Fan> 30mm for motor or 25mm
8. <Likes of your setup> In progress of putting together
9. <Dislikes of your setup> Same as above
10. <Description on your motor performance> Same as above
11. <Battery Life> Same as above
12. <Pinion/Spur> 14/46 (est @ 41mph
1. <Car> Mugen MBX6
#70
Just started working on my rig... still waiting on the availability of some of the items
1. <Car> Caster Fusion EX-1
2. <Motor> Neu-Castle 2650kv Motor
3. <Speed controller> Mamba Monster with onboard BEC
4. <Lipo Battery> (2) Diggity Designs 5300mAh 28C 7.4V
6. <Conversion Kit> None - Factory Built!!
7. <Cooling Fan> Hopefully none will be necessary
8. <Likes of your setup> Balanced battery setup
9. <Dislikes of your setup> That I don’t have everything I need yet
10. <Description on your motor performance> It will be a Mamba… nuff said
11. <Battery Life> Hope to get 20 minutes of good runtime
12. <Gearing> Don’t have a clue yet
#72
Here are my current conversions:
Kyosho ST-RR
Neu 1515/1Y/F
MMM v2 with v3 case using external Bec firmware 1.20
Lipo 4s1p Neuenergy 5000mah
Charger Hyperion Duo
Conversion Kit RC-Monster motor mount, custom disc brake and batt tray
Like - one of the best handling truggies in my opinion
dislike - expensive
gearing 14T/48T
Mechanical brake in front/motor brake for rear.
Kyosho SP2 777
Neu 1512/2D/F
14T/47T
likes - handles well, durable
dislikes - expensive and heavy
Jammin CRT.5
Neu 1509/2D
MM with fan and external BEC
Zippy-R 3s1p
RC-Monster motor mount custom batt tray
likes - most fun to drive
dislikes - none
13T/46T
Motor brakes all around
Kyosho Kanai III converted to CORR style truck
Neu 1515/1.5Y
MMM v2 with v3 case using internal bec firmware 1.20
14T/46T
Traxxas REVO PE
Neu 1515/1Y/F
Maxamp 4s2p 6000mah
Tekno motor mount and battery tray
14T/38T
Center diff, front and rear disc brakes
TrueTrac
Kyosho ST-RR
Neu 1515/1Y/F
dislike - expensive
gearing 14T/48T
Kyosho SP2 777
Neu 1512/2D/F
14T/47T
Jammin CRT.5
Neu 1509/2D
Zippy-R 3s1p
dislikes - none
13T/46T
Neu 1515/1.5Y
14T/46T
Traxxas REVO PE
Neu 1515/1Y/F
Maxamp 4s2p 6000mah
14T/38T
TrueTrac
#73
I have been thinking of converting my 8ight. This thread is a big help. I do have a few questions though.
I see more people in this thread are using the RCPD conversion than the Losi conversion. Is there any reason for this?
Are you guys all running a single 14.8V Lipo or 2 7.4V Lipos?
The price of the batteries is really the big reason not to convert. Seem there are only 2 options; the really expensive Losi Hard cased battery with a 25c rating or the cheap soft batteries with a 15c rating.
Also I think this is the "new" thing in off-road racing so I would think there is a lot of new products in the works. Maybe some 100% engineered electric 1/8 scale buggies. Also I live/race in Japan and this hasn't caught on much yet on this side of the Pacific.
#74
nsr250repsol,
RCPD makes a high quality conversion kit. When you choose the Ultimate battery tray it provides a very clean installation.
I have used both a single 4s 14.8v battery and I have tried 2 x 2s 7.4v batteries (wired in series) and the single battery has a lower center of gravity due to the reduction of packaging.
My crystal ball tells me that we are on the verge of higher C rated batteries being released (between now and the spring). Until now 25c were the top discharge rate but before the spring we will see 30 and 35c become available at the same prices as the current batteries or even lower. When choosing batteries I would rather have a TRUE 4s pack which is made up of 4 battery cells wired in series as apposed to a 4s pack which is made up of 8 battery cells which are wired 2s 1P.
#75
