Old 03-05-2008, 02:46 PM   #1
drtdawg's Avatar
Default losi diff
i have a xxxt-cr i race on a high bite clay off road track and after 3 or 4 runs the diff is crunchy and i have to clean and re grease after 6 to 8 runs i have to replace rings and thrust assembly is this normal or am i doing something wrong
drtdawg is offline   Reply With Quote
Old 03-05-2008, 03:28 PM   #2
Casper's Avatar
Trader Rating: 33 (100%+)
Your slipper is too tight. Loosen the slipper so it always give before the diff does and your diff should last months.
TLR/Losi Team Driver
TLR/Losi | Tekin | Venom | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-06-2008, 05:46 PM   #3
Trader Rating: 66 (100%+)
Default Correct
You always want the slipper to slip before the diff. Otherwise you get the results you have. If the slipper can't move, the diff has no other way to react than to wear out the diff rings, balls, thrust rings, and thrust balls. Replace all of it and use a new nut in the diff. Then break in the diff and make certain you start with the slipper loose and tighten it after the diff is broken in. Make certain by pulling full throttle and listen for the slipper to slip and not the diff barking.
nutz4rcyktw is offline   Reply With Quote
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 07:49 PM
losi xxx-t diff offtraxx R/C Items: Wanted to Buy 7 08-29-2008 05:37 PM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 10:11 PM
Losi XXX-S one way diff polesitter61 R/C Items: For Sale/Trade 1 08-15-2005 12:58 PM
Losi XXX-S/XXX-4 ONE WAY DIFF LOSIRACIN2005 R/C Items: For Sale/Trade 3 03-28-2005 06:23 AM
SEO by vBSEO 3.5.0
