Brushless newbie question
I have a 1/10 off road truck that I am going to convert to brushless and I have a 12 turn double motor in it and I want a faster brushless motor and I'm not very knowledgeable on the brushless stuff so any help would be nice.
My vote would be for a Castle Creations Mamba Max 5700 system.
10.5 is just slightly faster then a 19 turn try 6.5,7.5, or 8.5. I think 7.5 is what your looking for.
the novak 5.5 has a lot of push to it but your back end may be all over the place. possibly start out with a 6.5 and go from there. good luck.
http://www.BulldawgRC.com
BL SETTUP
HI HYPERGUY, I'M NEW BEE ALSO IN OFF ROAD. MAY SHARE UR BL 5.5 GEAR RATIO? BECAUSE I ALWAYS OVER HEAT THE MOTOR TILL PROTECTION CUT OFF!! MY GEAR RATION NOW USING ABOUT 11.7!!
I GEAR MY T4 AT 16 OR 17 WITH THE 86 SPUR, WITH THIS GEARING I CAN RUN THE WHOLE PACK IF I WANTED TO AND THE MOTOR COMES OFF AT 95-100 DEGREES AND THE ESC 100-115 THATS ONLY IF I RUN THE WHOLE PACK THOUGH
I dont know about that- I would totally agree that a 5.5 is too much motor unless you are just doing speed runs up and down the street. 6.5 is a perfect motor for Mod Truck (may even be too much for some on dry/loose conditions).
