Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-12-2008, 08:00 AM   #166
nc-hopsing's Avatar
Originally Posted by tcmerf View Post
Finally ordered mine. I still have not seen one in Socal. We need a few at OCRC so we can get a class going!
Frank Root has been running his J82 in demos at the JBRL electric series races during main setup. That thing is pretty sweet. And he still has the truck shock setup, he hasnt had a chance to play with set ups yet.
Steve Butts
KYOSHO AMERICA.com - Team Orion.com - kyoshoforum.com - Team SlantEyEs - Hardkore Paint - JBRL Off Road Series - JConcepts.net - DarksideDesigns.net
nc-hopsing is offline   Reply With Quote
Old 06-12-2008, 08:11 AM   #167
Cool. I have not made it to the JBRL races at all this year. I just saw the thing for the class at the Nats but i dont think i will be able to get the time off.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 06-12-2008, 08:28 AM   #168
Bulldawg RC's Avatar
Trader Rating: 28 (100%+)
contemplating a J82 for the second round of jconcepts super cup. i guess only time will tell. they look great and stability looks amazing.
Bulldawg R/C Batteries and Products
Nimh and Lipo Batteries and accessories
www.BulldawgRC.com
We offer the highest quality at the best prices!!
Bulldawg RC is offline   Reply With Quote
Old 06-12-2008, 04:28 PM   #169
speedsterblade's Avatar
mine.. Put only a couple of laps in on the j82 but it was good to drive.
The rest of my 2wheelers...got a b44 body to match up for the full AE/JC hybrd family.
speedsterblade is offline   Reply With Quote
Old 06-12-2008, 04:56 PM   #170
2wdMod's Avatar
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 20 (100%+)
man, I liked the J82 so much after I did my t4 I had to try it on another truck so I did an evader ST pro as a J82. Check out the pics.
2wdMod is offline   Reply With Quote
Old 06-13-2008, 05:39 AM   #171
PW
PW's Avatar
Send a message via AIM to PW
Looking good guys! This class is so much fun to drive that it should become the standard buggy class...Ha
JConcepts - Team Associated - LRP - Reedy - P-Dub Racing - BMI Racing - Parma - JAB Graphix
"If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 06-13-2008, 06:34 AM   #172
cla5675's Avatar
I've got an old Losi XXT-CR and I've been contemplating a J82 conversion. If I remember correctly the Evader ST is almost the exact design of the XXT trucks. How did you mount the body? Velcro on the side of the chassis and body? Also, were there any modifications needed or did every thing just bolt right up? Thanks.
cla5675 is offline   Reply With Quote
Old 06-13-2008, 04:38 PM   #173
2wdMod's Avatar
It took a little doing to do the evader j82. I used kyosho wing mounts from the RB5/ZX5 and had to drill some holes in the rear shock tower to mount them. The body is fastened with velcro, I used a evader BX body since the evader st and BX use the same wheel base/ chassis. The wheels bolt right up in the rear, the fronts I had to use some B4/t4 wheel bearings to run the Jconcepts front wheels, and I used an el cheapo 2.00 associated 7" wing.The evader j82 is a rough track machine!!My t4 j82 handles rough tracks pretty well, but the evader j82 just blows through the rough stuff without ever getting out of shape.
Old 06-13-2008, 04:53 PM   #174
By the way am i going to have a problem fitting my TC Spec under the body with the fan still on it or do i need to take it off?
FT B44 - FT J82
Old 06-13-2008, 05:08 PM   #175
2wdMod's Avatar
I dont know on the lrp, I would say you will probally have to ditch the fan. I know I dont have room for the fan on my novak.
Old 06-13-2008, 05:15 PM   #176
cla5675's Avatar
The XXT and XXXT use the same front wheel bearing as the T4(3/16x3/8), so I won't have to modify anything there. I use XX-4 wing mounts on my XX buggies, so I can probably use a set on the XXT. I guess I'll just have to get creative when I mount the body. Thanks for the info!! I'm going to order the kit sometime next week.
Old 06-13-2008, 07:48 PM   #177
Davidka's Avatar
Trader Rating: 22 (100%+)
A Losi based J82 conversion will be much wider than an Associated based version. The XXXT uses wheels with alot of inboard offset and is the same width as a T4 with wheels that are offset outboard. If you put the J82 wheels on a XXXT it will probably still be as wide as the truck was.
Old 06-14-2008, 05:49 AM   #178
cla5675's Avatar
If you use the XXXT-CR VLA (Variable Length Adjustment) arms with the spindle/knuckle assembly mounted in-board, then you might be able to have a front width that's pretty close to a T4/J82. Just a thought.
Old 06-14-2008, 08:18 PM   #179
Send a message via AIM to pistolpete
Hey PW. Could you please post the setup you were running in the video? The track surface looks alot like the one I run on. Also have you run the harder front tires yet? Thanks.
pistolpete is offline   Reply With Quote
Old 06-15-2008, 11:19 AM   #180
AndyMoore's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to AndyMoore
We do have the harder fronts available now, #3000-00. Im sure PW will chime in with his setup.
|Kyosho America|Team Orion|JConcepts|Jab Graphix|oOple|Winning Edge Designs|RC Signup|Pacific Coast Hobbies|
AndyMoore is offline   Reply With Quote
Forum Jump
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 02:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 08:37 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
