Old 02-15-2008, 02:46 AM   #1
TroyTroy's Avatar
Default mini problems need help
hey i bought a losi mini 18 baja a couple days ago . its had 3 batterys runs threw it. and on the last turn it all of a sudden it had a buzzing sound. so i took to the motor and all the diff apart. and the spur gear i think it is was making the noise. when i took it off there was no noise.would it just be a naer gear needed? and second problem is theres a sorta ticking sound sometimes in runtime. what may be causing that?
all surgestions and comments will be greatly appreciated.
TroyTroy is offline   Reply With Quote
Mini LST2 Problems with ESC shutting off kld4972 Electric Off-Road 0 04-15-2008 09:18 AM
Mini T glitching problems Langford2000 Micro and Mini Scales 9 01-23-2008 08:15 PM
New Mini Baja - Two Problems JatoTheRipper Micro and Mini Scales 7 09-17-2007 04:15 PM
Tamiya Mini 4WD gear problems flash1986 Micro and Mini Scales 1 07-18-2007 05:42 AM
Mini SLT. Problems Hellfire1 Electric Off-Road 3 02-08-2006 05:58 PM
SEO by vBSEO 3.5.0
