ASK Ronnie Gardner(Kyosho Electric Offroad)
#19
memyselfandI: this was my set up from crcrc(dialed) below. IM still running the car from the worlds..note about that car though it is the same car to the t except for the chassis and top plate...The Kyosho car is really good and has been good everywhere i have gone...i think it is overall a better car then the losi..cant wait to get to the bigger races this year to show you guys what i am talking about...
Front:
3-B Pistons
35wt Losi Oil
light yellow Front Springs
No Limiters in shocks with shock ends unthreaded 2 turns
25 degree kick-up/.5 mm spacer used
Shocks mounted in inside location on tower and outside location on the arm
2-B Camberlink with no washers under the ball stud (middle on bulkhead/outside on caster block)
Spindles in upper position
1/4oz of weight under steering rack
Rear:
3-a Pistons
30wt Losi Oil
Dark Yellow Rear Springs
No Limiters in shocks with New W5183-02 Shock Shafts (54mm) (The stock RB5 shock shafts are 50mm and are too short...do not use)
Shocks mounted in middle location on tower and middle location on New LA243 arm
2-B Camberlink with no washer under ballstud on shock tower brace and 1 mm washer under ball stud on hub
(middle on shock tower and outside on hub)
Hubs spaced in the middle position
Hub height all the way down position
Stock Anti-Squat stock
1 oz under rear tower
Extra Info:
Battery Position - Forward
Ride Height - 24mm Front / 22mm Rear
Pro-Line Cavalieri Edition Mid Wing
racer34v: not sure at this time but i dont think so...The laser is a good car to start out with if thats what you are doing...but i know people always want the best of the best if so go pick up the sp car, it is easy on new comers.
SQC049: Will that is info that i dont even know and am sure im not suppost to give out...but if i do get some info on that you guys will be the first to know.
DanGriffin: all i have to say is wow! haha whats up man?
Slant EyEs: well Slim at socal gave me the nice name for some reason and i guess it just stuck..haha
Joe Pillars: Heck ya you better be ready to be dominated in MX vs ATV!
Exterminator: not going to make it to the rage this year..
ROOOOOOOT: come on man cheese it better on everything...
DustinR: YES i am a colts fan lived 5 years of my life growing up in speedway indiana...GO COLTS!
for the loose track people this is what i run on the looser tracks!
Front:
3-B Pistons
35wt Losi Oil
Orange Front Springs
No Limiters in shocks with shock ends unthreaded 4 turns
25 degree kick-up/no spacer used
Shocks mounted in middle location on tower and outside location on the arm
Rear:
3-a Pistons
271/2wt Losi Oil
Shocks mounted in middle location on tower and inside location on New LA243 arm
2-B Camberlink with no washer under ballstud on shock tower brace and 1mm washers under ball stud on hub
Stock Anti-Squat (2 degrees)
Tranny is raised 1mm
Extra Info:
Ride Height - 25mm Front / 23mm Rear
Front:
3-B Pistons
35wt Losi Oil
Rear:
3-a Pistons
30wt Losi Oil
Extra Info:
Front:
3-B Pistons
35wt Losi Oil
Rear:
3-a Pistons
271/2wt Losi Oil
Extra Info:
#20
whats up RG? you over the rain?
#21
#23
rcdude19641: no not really its kinda a change for once..
S Bowen: haha sorry it means tranny raised 1 mm..haha
Slant EyEs: no comment..haha
#25
wat was the purpose of raising the tranny? thanks
#26
Hey Wheeler, your shirt stole some of your ranch!!!! Hahahaha.
Canyon
Canyon
#27
Zac R: hows it going Zac...umm gear it about 17 should do the trick.
craziracer: changes the dog bone angle...and the roll center
spdtch:haha...i will always remember that..haha what you been up to canyon?
#28
#30
i'll forgive you if you come back next year to LAY IT DOWN!
