lipo batterys
Old 01-20-2008, 07:58 PM
Default lipo batterys
looking to but a new 7.4 lipo for 1/10 i am looking at the orien or the trinity and looking a voltage cut off for gt7 esc
losiboy is offline
Old 01-21-2008, 05:19 AM
gndprx's Avatar
Trader Rating: 18 (100%+)
Here is a pack that is based off the Trinity packs with a built in LiPo cut-off.
http://tmxpress.net/products/product...roducts_id=156
I have ordered one from John and have heard good things about them. The only downside is the lower capacity.
gndprx is offline
Old 01-21-2008, 07:21 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
great price. Only concern I have is the whole no warranty thing. Other guys at least they will offer a 30 day warranty.
Do they have balance plug on the pack like trinity?
Cain is offline
Old 01-21-2008, 07:42 AM
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Love my orion/peak lipos !!!! i travel llight to the track now.
Jason Pelletier is offline
Old 01-21-2008, 08:36 AM
gndprx's Avatar
Yes. I was told it was a hyperion style plug. Mine should be here Wednesday to verify. I've been talking with John Tag about this pack for a while before I bought one to test with.
I can't comment on the "no-warranty" thing at the moment because LiPo vendors are still in huge flux right now. I'm sure if there was an obvious problem you could discuss with with John and work something out, but don't quote me on that.
gndprx is offline
Old 01-21-2008, 04:28 PM
I have a 4800 Orion and love it. I run the Sphere without a lipo cutoff and it works fine. I installed the Novak li-po cutoff on my Sphere and it caused problems so I just removed it. I would just run the lipo, you will know when you need to charge the battery before you hurt it. I've run that battery for a good 20 - 25 minutes on the track practicing one time, impressive.
I LIKE IT XXX is offline
Old 01-21-2008, 04:48 PM
Trader Rating: 27 (100%+)
wow...awesome price. who cares about no warranty, I have faith in my ability to not screw it up
convikt is offline
Old 01-22-2008, 07:23 AM
Tech Legend
Cain's Avatar
So I take it if for some reason the pack came and had a bad cell in it, you wouldn't complain or want another pack??
Cain is offline
Old 01-22-2008, 07:25 AM
SQC049's Avatar
Trader Rating: 18 (95%+)
I've been running the Orion 4800 in my 2wd and 3600 in my 4wd. I love them both. Lipos are a God send.
SQC049 is offline
Old 01-22-2008, 08:06 AM
VOODOO+'s Avatar
I've had 2 Orion 4800 platinums and I have 2 trakpower 4900 goldbrick lipos. I notice no difference in performance between the 2 though the trakpower is a 25C and the orion is only a 15C. I like that the trakpower uses 2S1P instead of the orion's 2S2P.
Not that they need to be balanced, but the Orion Platinum 4800 in the 2S2P configuration can never truly be balanced because there is no way to isolate the cells. Small issue, but other than that the Orion 4800 is a great pack.
The Orion 3200s and the 3600s are 20C and 25C packs respectively and are wired 2S1P, you'll just have to add more weight to meet ROAR guidelines (if you need to).
VOODOO+ is offline
Old 01-23-2008, 05:40 AM
gndprx's Avatar
I'm sure if that was the case and you contacted John immediately that he'd work with you.
Mine should be here today! If it works out well enough, I'll probably order at least one more.
gndprx is offline
Old 01-23-2008, 06:16 AM
Tech Legend
Cain's Avatar
Thats good if he will. I guess when I see something stated as being sold as is, it just worries me that if it does come in dead, or goes dead after a cycle or two, there is a possibility of getting stuck with a paperweight.
Anyone heard if higher mah packs are in the works from other companies?
Cain is offline
Old 01-23-2008, 06:23 AM
Default lipo
Max amps has some really high packs.
MRorange is offline
Old 01-23-2008, 06:25 AM
gndprx's Avatar
MaxAmps, ThunderPower and TrueRC all have 8k or higher. Of those, MaxAmps is the only one putting a hard case as far as I know and you have to ask for the option.
gndprx is offline
Old 01-23-2008, 08:41 AM
No, that statement is absolutely incorrect and not accurate at all. A single Lipo cell is actually a bunch of smaller Lipo’s batteries welded in sealed aluminum pouch. This means, when you wire up two Lipo's cells in a series, (as seen in the Orion example) you are basically moving the connection outside the pouch. Hence, the two Lipo's cell wired up in a series on either the + or the - side of the Orion pack act as a single new Lipo cell, and they will not go out of balance for this reason, EVER!
Once understood, and know how and throughly research how a Lipo cell is created in the first place, you can clearly easily see why this is not an issue at all. In additon, this means a 2s1p pack isn't necessarily faster than a 2s2p pack!
4wd Racer is offline
