Total Newbie battery question
:confused: :confused: :confused:
Be nice to the newbie here... My son has a Duratrax Evader EXT with two Venom 1800mah NiCD batteries. The batteries really do not last very long and I want to get him some better ones. His buddy has a Venom 3000mah NiMH that is black that seems to last much longer and not lose power as quickly. I have seen black and green batteries with the same amperage. Is there a difference between the Venom black and green batteries? What is the best battery to use? The green Venom 3600mah NiMH is $30, that is about what I can spend. Thanks, Mike. |
I would just pick up some more of the 1800s. The brushed motors that these cars use are not really designed to run for more then 6 minutes w/out cooling off for a few minutes. I would just run the 1800s & switch them out. If you bring 4 of the 1800s out you can spend a good bit of time running the car any ways.
1800 is kind of low in capacity especially when people are running 4200-4600.
You may want to buy some nice used matched 3800 side by side for about $15-$20. Just look in the for sale section. |
dbl post.
