1000 gram 2wd
#16
I don't know which is better... all I can say is that it seems many have tried lighter cars (gone lipo...) and messed with the setup, etc... but they end up adding weight to be at least close to what a "nickel" car is.
I'm not saying a light car won't work or is a bad idea... maybe more r&d is needed to find the right setups.
But for now I'm adding weight to my lipo 1/10 car.
#17
Company Representative
So are you saying that the cars we have now are to easily breakable??? our whole program are brushless 1/10 scales and out of 42 drivers last weekend we only had 2 not finish due to breakage. also the way a track is built will save cars. Poles that hold the building up and blunt objects break things. if you want to reduce price run the lrp ai brushless set up or the novak evx. Who said it has to have a gagillion profiles to be fast!! both speedo esc combos for around $160 they both do the job well and have plenty of power for 2wd. I think that beats putting all the money into redesigning the cars for different electronics. my .02 not trying to offend anyone or downplay anything thats been said.
#18
It would be nice to see the weight rules remain the same and the manufacturers use the lightweight properties of lipo technology to make up the difference and beef up some parts and lexan bodies.
#19
If you run a lighter buggy then there would be less stress on the parts. There are tracks where people do have trouble finishing though.
#20
Thereis one reason and one reason only that 1:1 racers reduce weight at all costs and model racers don't: horsepower limitations. They have it and for the most part, we don't. If all racing were say, stock class, every racer would try to keep his vehicle as close to the weight limit as possible. In modified, we have so much more power than we can use that extra weight does not translate into the disadvantage that it would if horsepower were a real limitation to performance.
#22
You cannot keep getting more and more grip by just going to softer and softer tires. On many surfaces, you still need the weight to push the tire patterns into the ground. On asphalt, you this limitation is not so obvious because the rough road surface can dig into the softer tire. On loose dirt, softer tires will just grip the loose top soil better but harder ones can dig deeper. So softer isn't always the answer.
#23
Of course, this whole argument is difficult to prove for anyone. We are just sharing opinions here...we know it's mostly going to come down to the driver...not a few grams here and there...
#24
#25
We're going to have to agree to disagree here. Not all 1:1 classes have HP limitations. Personally, I can't think of any. Yes there are limits on displacement, fuel delivery, and other things. In F1, there is as much as a 50HP difference between MF's cars and they all strive to meet the absolute minimum weight requirement to get that edge. I agree, the shear amount of power available in Mod racing is sometimes a crutch more than an asset. However, lighter cars will accelerate, brake, and change direction faster.
A lighter car should do all of those things but until we can find spring rates that accomodate the weight change it is a challenge to come up with a setup that has as much traction and stability to match the heavier car with no power/acceleration disadvantage.
#26
If you havent already, I suggest that you weigh your stadium truck. You will discover that its already 250-500 grams over the ROAR weight limit.
Moreover, the T4/B4 set ups posted on the AE website suggest adding weight thus disproving that a lighter car is a faster car.
#27
Or, maybe they don't say why at all. I wouldn't use that bit of info as a way of "disproving that a lighter car is a faster car". It just doesn't make sense.
#28
Yeah, your right, Cavalieri, Tebo, Maifield have no idea what they are doing!
Sorry to use the sarcasm, but, to put it in perspective, AE designed the T4 to be heavier than ROAR rules and their drivers are adding weight to it. The people who design and race the cars for a living are advising you to add a few grams to your car to make it easier to drive.
I don't know why. Maybe motors and batteries have improved over the last 10 years to the point where they have exceeded a reasonable power to weight ratio that makes driving them too unpredictable unless they have some strategically placed ballast.
#29
Nitro R/C is about the closest thing to real world racing in the fact that the engine size limitations and the fact that any internal combustion engine can only produce as much power as the air it is flowing ( which is about the same HP level most .21 off road engines have been making for over 5 years now )
so HP is limited in theory combine that with a minumum weight limit and you have controlled HP cars that are all about the same speed on the track. Then compare this to electric modified which has battery tech that is constantly evolving and the batteries are the real producer of the power in electric, motors and ESC`s are merely portals for the electricity to spin the wheels, so therefore once again the idea of running less voltage batteries etc. comes into play, 5 cell etc. because unlike nitro which is pretty much always going to be limited by the engines displacement for HP, electric can constantly add cubic inches to its engine basically by having greater power batteries.
#30
I don't think AE and Losi designed their cars around any specific weight. Remember, both the XXX and the B4 designs came out when we were running 2400mah NiCds and 3000 Nimh's. These batteries were 3-4 oz lighter than the current 6 cell packs people are using. The added weight in those setups are not to make the car heavier, they are a balance adjustment. If heavier was truly faster the weight addition would be greater. I have not heard of Cavaleri, Tebo strapping lead everywhere they could in the chassis.
For what it's worth, the only driver that could stay in sight of Cav at the Midwest champs (in Mod Stadium truck) was Brian Kinwald running BL and Lipo with just enough weight to be legal.
