Kyosho LAZER ZX-5 Rim/tire question >
Old 01-06-2008, 01:26 PM
Default Kyosho LAZER ZX-5 Rim/tire question
Hi, i have a ZX-5 i use on asphalt. Im using Pro-line dirt hawg 1 & 3 R/F
Im thinking of going with Panther slicks there low profile http://www.pantherteam.com/index.php...roducts_id=239
My question are there any other rims that fit the LAZER besides Kyosho's Like Losi Or something i could dye?
I have raced a lot of Touring cars, but with a 4WD on road car should i use softer spring & and shock oil. Also i replaced the center to a one way instead of all time 4WD any problems with doing that.
Thanks!
yessongs is offline
Old 01-06-2008, 02:06 PM
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
For the zx5 you can get a proline conversion axle from kyosho that allows you to use losi and associated rear rims. The axles work with the cvd/universals but not the swingshaft/dogbones.
You an take out the one way, put a front diff. If you have a shaft oneway, there is a part to convert it to full 4wd.
I dont have any part numbers at the moment. Also, if you post this on the kyosho offroad thread, there are many people more knowledgeble than I that can assist you.
BillyCaldwell is offline
Old 01-06-2008, 08:00 PM
Its a shaft one way i can convert it back.
Thanks! i posted in the kyosho offroad thread.
yessongs is offline
Old 01-06-2008, 10:40 PM
johnkemp's Avatar
your better off getting the proline adapters
johnkemp is offline
Old 01-07-2008, 02:58 PM
tmail55's Avatar
Trader Rating: 61 (100%+)
Part# ?
Checked on Kyosho America site and could not find them.
How about a link!
tmail55 is offline
Old 01-07-2008, 03:06 PM
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by tmail55
Part# ?
How about a link!
http://www.speedtechrc.com/store/ebp...id=560&id=6725
Turbo Joe is offline
