Old 12-30-2007, 12:36 AM   #1
Default BK2 vs. CR
Does anybody know what the difference is between the two?
I LIKE IT XXX is offline   Reply With Quote
Old 12-30-2007, 09:32 AM   #2
schmelme's Avatar
The cr uses EA3 composite parts. the biggest change was to the rear of the car it uses a "cr" pivot block in the rear with short arms. The rear hubs are a vertical ball stud design. The trans went back the original black case xxx design with a revised diff assembly.Both front and rear shock towers are different. The bk2 rear used hinge pin holders in the rear similar to a B4 with a longer arm, it used the grey gen2 case trans. Some minor stuff is changed as well like heavy duty ball studs. New motor plate and gear cover. New body,wing.
schmelme is offline   Reply With Quote
SEO by vBSEO 3.5.0
