Old 12-22-2007, 01:16 PM   #1
Boadazofa's Avatar
Trader Rating: 33 (100%+)
Default ball diff questions?
Just wondering what peoples thoughts are on ceramic balls to carbide diff balls do they last longer, what are there pros and cons.
How often do you replace the balls in the diff? Do you do it with every rebuild or should the last longer than that?
thanks in advance, i am still learning the electric game!
Lone Wolf
Boadazofa is offline   Reply With Quote
Old 12-22-2007, 01:39 PM   #2
NJA82's Avatar
Send a message via MSN to NJA82
Ceremic Diff balls will last longer and will be smoother and lighter than the carbide balls. Carbide balls should last for a few rebuilds, as long as the diff isnt set loose and allowed to slip the balls should last quite a while, running stock i used to get a full years racing out of them with only diff ring and thrust rebuilds.
Running modified i would estimate about 3-4 diff rebuilds and the carbide balls will need changing as well. You only have to rebuild ball diffs if they are very notchy/gritty and cleaning wont fix it. Usually a nice cleaned and regreased thrust bearing will get it back in top shape again.
NJA82 is offline   Reply With Quote
Gear Diff VS Ball DIff NOVICE4EVER Singapore R/C Racers 23 08-29-2012 09:03 PM
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 07:49 PM
NTC3 Complete ATD Diff, diff nut, pivot ball socket caps Judge Joe Brown R/C Items: For Sale/Trade 2 05-09-2008 09:18 PM
FS: T1FK'04, '04 Multi-diff, ball diff bbentley40 R/C Items: For Sale/Trade 4 05-17-2005 07:22 PM
ball diff went bad? SnipesXxX Electric Off-Road 3 03-03-2004 08:22 PM
SEO by vBSEO 3.5.0
