Old 06-11-2003, 11:13 AM   #1
Dill's Avatar
Default RC10GT front end questions
ok..as I mentioned in another post, the front end on my RC10GT needs some 'updating'
The lower shock ball joints (I don't know the correct term for these) keep popping out when I hit big bumps, causing the shock to collapse. I need new ones and wondered if there is a metal on metal replacement for these instead of the plastic.
Also, I keep bending the tie rods and the nuts fall off the ends. Is there a higher quality replacement for these? yes, I will loctite the nuts from here on out. The hinge pins and a arms themselves appear to be holding up so far...
Also, what are some of the stiffest springs available..right now it has chrome on the front and green on the rear, and the truck is way too bouncey even with 50 weight oil in the shocks. Thanks
Dill is offline   Reply With Quote
Old 06-11-2003, 05:35 PM   #2
rcgod's Avatar
Trader Rating: 27 (100%+)
Associated sells the inner part of the shock eyelet in steel. Not sure what the part number is. Get those with new shock ends and use a washer and they won't pop off anymore.
Get some Associated or Lunsfor tie rods in titanium to fix the bending issue.
Sounds like you don't need stiffer springs, you need thinner oil. If you're running offroad you should be using 35wt in the front with blue or silver springs and #2 pistons, and 30wt in the rear with green springs and #1 pistons.
rcgod is online now   Reply With Quote
Old 06-11-2003, 06:59 PM   #3
Dill's Avatar
thanks for the advice, I'll give it a whirl!
FS/kanai 2/rc10gt arr/mugen mst-1 w/parts/rc10gt roller mint/recievers/servos thedoc329 R/C Items: For Sale/Trade 9 02-02-2008 03:09 AM
2wd Front End Design. A few questions. silence360 Electric Off-Road 37 04-23-2007 04:16 AM
carbon fiber front shock tower RC10GT #7655 t4ftracer R/C Items: Wanted to Buy 3 12-27-2005 03:03 PM
Some rc10gt questions NitroRacerXX Electric Off-Road 32 09-26-2005 03:15 PM
Alum Tamiya TA04 Front Steering Block / Front Upright Alvin Singapore R/C Racers 2 02-04-2002 06:50 PM
SEO by vBSEO 3.5.0
