Mamba max 5700 won't calibrate with nomadio sensor >
Old 12-15-2007, 07:18 PM
agent 007.5's Avatar
Default Mamba max 5700 won't calibrate with nomadio sensor
Ok here is the problem, a friend of mine has a mamba max and when he goes to calibrate it with his nomadio sensor it wont fully calibrate. He holds the trigger down to full throttle and it reads it, but when he goes to full break it will sit there with the light blinking it wont go any further. has anybody else had this problem. Thank You.
agent 007.5 is offline
Old 12-15-2007, 07:25 PM
glassdoctor's Avatar
Try messing with the throttle epa settings, both brake and throttle end points. I can't tell you what will work but you should be able to get it to work that way.
The only radio I know of that doesn't work is the JR XS3 and I can't get it to work with LRP AI speedos either.
glassdoctor is offline
Old 12-15-2007, 11:28 PM
action135's Avatar
im not sure but try putting your settings to 100%
that should fix it
action135 is offline
Old 12-16-2007, 09:45 AM
Thanks guy's I will tell him to make sure all his epa's are up all the way.
