Old 11-26-2007, 01:06 PM   #1
simba's Avatar
Default FT B4 keeps blowing the shock seal. WHY ???
why am i blowing my rear shock seal / o-ring. Twice now in a row my rear shock has blown all the oil out, when i rebuild the shock and replace the o-rings the old o-rings look absolutely fine, i replace them anyway.
My thoughts are that our track is quite rough at the moment and the green springs in the rear are too soft, and the shock itself is taking a pounding thus resulting in too much pressure internally on the o-ring and its letting go, so perhaps a heavier rear spring set would absorb more of that compression and take the pressure off the shock.
is my theory correct or dribble.
Team Associated Factory Team B4
Futaba 3PM 2.4GHz Spread Spectrum
Novak GTB Spread Spectrum ESC
Sponsored by Billowy-Power Batteries
PM me for the best priced ROAR approved lipo on the market
simba is offline   Reply With Quote
Old 11-26-2007, 01:07 PM   #2
joe of loath's Avatar
could be your pistons building up pressure inside. try pistons with more holes perhaps?
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 11-26-2007, 04:01 PM   #3
make sure you are getting the white clip inside the shock seated properly. sometimes if there is excess flashing on it, it will pop out....
hated1racing is offline   Reply With Quote
Old 11-26-2007, 04:23 PM   #4
BuggyKing's Avatar
Trader Rating: 17 (100%+)
are u replaceing the other parts too. Make sure when building em u make sure they snap in correctly. I use green slime on o-rings before assembly.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 11-26-2007, 04:26 PM   #5
Send a message via AIM to playboy Send a message via Skype™ to playboy
you probably are putting too much oil in the shocks
playboy is offline   Reply With Quote
Old 11-26-2007, 04:38 PM   #6
After you fill the shock before you put the spring on make shure that the shaft goes all the way up if it stops before the shaft is allmost all inside the shock then its to full and you will blow out the bottom and even maybe the top just my 2 cent hope it helps
eric l is offline   Reply With Quote
Old 12-02-2007, 11:57 AM   #7
hyperguy's Avatar
Trader Rating: 22 (100%+)
i was having the same problem until i made sure that all of the flashing was trimmed off before putting them in. my problem was solved after that
hyperguy is offline   Reply With Quote
Old 12-02-2007, 12:38 PM   #8
d4man's Avatar
Are you using the red AE O-rings or the Blue MIP o-rings? If you're using the Blue MIP's and not bleeding your shocks properly, that could be the cause.
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 12-02-2007, 01:36 PM   #9
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
Your either overfilling the shocks with oil, or the o-rings are getting pinched upon assembly. You can try silver springs instead of the green ones. This may help but its hard to tell. If you go up one to the silver springs try dropping your oil weight by 5.
Example instead of 30w try 25w with the heavier spring.
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Blowing servos jgtruggy Nitro Off-Road 12 04-13-2008 10:14 PM
blowing plugs spudly12 Nitro Off-Road 6 12-28-2007 03:41 PM
OS 18TM/TZ Spring/Header seal/Carb seal weidjd R/C Items: For Sale/Trade 1 09-19-2006 08:44 AM
Why? (Blowing plugs) Bob Moore Electric Off-Road 8 07-17-2006 12:19 PM
battery blowing up davioh Electric On-Road 11 04-20-2003 09:55 PM
SEO by vBSEO 3.5.0
