Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-27-2008, 07:24 PM   #286
yes I have 6,5 in revo and have run 30 min with no problems. I have the 4,5 also but it kills the batteries real fast.
xxxtruck is offline   Reply With Quote
Old 04-27-2008, 08:41 PM   #287
Cain's Avatar
Trader Rating: 34 (100%+)
Originally Posted by kvrc View Post
cain i have a novak hv 6.5 system in my 1/8 buggy. while i have never tried to make it run on 3s i am sure it could.
the problem would be that the 6.5 system is more or less about the same speed as a nitro on the track. with 3s i just dont think it would be fast enough. the 4.5 system thermals even faster than the 6.5 and on 3s it might be ok but i still think it would be too slow.
i really like the 6.5 system but it just thermals too easily in race conditions. i dont blame novak for that, remember they originally made it for a monster truck and with all the air it gets with the truck body it works great.
now the new systems they are introducing is another story, if they still thermal with their new motor mount system then its their fault since they are marketing them specificly for 1/8 use.
Curious about that. I am thinking that with Less voltage, hence keeping your temp down, you can gear up to gain back speed.
If any has tried it, would be interesting to see none the less.
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
Old 04-28-2008, 06:22 AM   #288
kvrc's Avatar
yes if i took 25% of the voltage away it would run cooler with the same gearing. but as soon as i would try to gear it up to make up for the difference it would most likely just put strain on the system and thermal again.
plus the novak system just dosent have the massive torque that the nue motors have so i dought i could gear it back to the same speed without killing the bottom end.
this is the same problem the mod touring cars have had since going to 5 cells. to get the cars back up to speed they just kept throwing a bigger pinion at it and then the motors started to fry from the strain.
kvrc is offline   Reply With Quote
Old 04-30-2008, 11:55 PM   #289
SuperEk4's Avatar
Can I use a Novak GTB to run a FEIGAO 9XL on CRT? max 2s only rite? Will it overheat?
CRT RCM, slip diff, Neu 1515/3d, HW150
X2CR, slip diff, Neu 1512/2.5D/F, MM
" First 1/8 Ep racing team in singapore "
http://8scaleracers.web44.net
SuperEk4 is offline   Reply With Quote
Old 05-01-2008, 06:28 AM   #290
tschenck's Avatar
Trader Rating: 23 (100%+)
the gtb will only run sensored motors, a feigao 9xl is sensorless.
tschenck is offline   Reply With Quote
Old 05-07-2008, 09:56 PM   #291
two weeks and the kits should be out.
Old 05-10-2008, 09:28 AM   #292
Default New information on Teamnovak's site
With Novak releasing the assembly instructions and more as built photos, any comments from folks who have built similar cars? Thanks
MartinB is offline   Reply With Quote
Old 05-10-2008, 04:44 PM   #293
Trader Rating: 40 (100%+)
I made my own conversion on an ancient GS Storm that used to be a Fine Design car. The motor is mounted over the center drive shaft and has battery trays on each side of the chassis. I have run it in two races and about 10-12 [pair of] packs total.
We haven't had real hot weather yet, but the motor (a 6.5 with the 5MM shaft conversion) hasn't gotten real hot (maybe 120?). The speed control was getting pretty hot before I added the fan but is now holding around 140 to 150 after a 10 minute run. It actually may be a little more than that - I can't temp it until I get the body off and it takes a minute or so to get to the car and turn off the switch after a run and the fan takes the temperature down pretty fast.
I'm geared 9-46 (yes: NINE to 46) with the standard GS Storm diff ratio of 3.31 (or so). I am right about even speed-wise with the good nitros while still running NiMH batteries but this is a very short track. I feel pretty certain I will be faster with LiPos if for no other reason than the elimination of 3/4 pound of weight from the NiMH packs. The RTR weight with the NiMH packs is over 9 pounds.
Everybody that has seen the car thinks it is pretty good but I am sure when I get my 8ight/Neu/Lipo conversion done it will blow away this car. I figure I could gear up and go a little faster, but would be concerned about ESC temperatures. Maybe I'll try it an see what happens.
ta_man is offline   Reply With Quote
Old 12-15-2008, 09:31 AM   #294
Default You have it wrong!
More voltage equals less current draw and less heat! The whole point of running 5s or 6s is to bring down the current draw. That is what generates the heat. Higher voltage systems use their energy more efficiently.
wwoodruff is offline   Reply With Quote
Old 12-16-2008, 01:49 PM   #295
derek_18mt's Avatar
http://www.shopatron.com/product/par....18878.0.0.0.0
Will this conversionwork on a Kyosho st-rr? please say yes lol, AWSOME PRICE!
derek_18mt is offline   Reply With Quote
Old 12-16-2008, 05:44 PM   #296
i am looking at sendind in my 4.5 motor and was wondering if i could get some info on the 6.5 and 7.5 motors , its for an rc8 buggy 4s
i am thinking i want the 7.5 but have heard it doesnt have as much punch/torque as the 6.5 , i plan on racing this and am hoping for some info , runtime , temps. , thoughts , etc.....
ERC8
entjoles is offline   Reply With Quote
Forum Jump
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 18865 11-18-2009 04:00 PM
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Novak electric conversion???? playboy Nitro Off-Road 7 05-21-2008 06:13 PM
Novak 1/8th-scale BL Conversion Kit xsxracing Electric Off-Road 2 12-06-2007 11:13 AM
Novak 1/8th-Scale Brushless Conversion Kit k£v!n Electric Off-Road 5 11-23-2007 10:07 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
