Can this car use Associated or JConcepts wheels? I would like to get someone started into 4WD and give him some tire/wheel sets I run with my B44 to help him even a bit. Thanks.
Yes it should be able to. It uses the Losi xx4 style wheel fittings front and rear which is pretty much standard on all 4wd buggies now.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
im planning to get 3-racing c-hubs for the 501x. my questions are:
this is a direct fit on the durga, right? the only difference is the horizontal camber link placement on the c-hub, instead of vertical (for stock), meaning i can use the stock ball stud, right?
I recommend to any body who is a Durga owner that you buy the aluminum suspension mounts that 3racing makes. They are available for the front and rear and make the buggy feel more solid. The quality of the material ( aluminum) Is very good. Does anyone own the new dampers for the Durga? Mine are on the way from stella as we speak.
alright guys, i have read the forum and seen all the arguments against the durga and 501X, but i am a budget weekend racer.
my budget in mind, has anyone ever thought to compare the Durga chassis to the DF03 chassis as far as a weekend racer goes. i dont race anything competitively, just weekend club meetings.
to me the Durga is like and off road version of the TA05.
and an equal comparison the DF03 would be a class like a TB01.
am i way off?
i understand the obvious differences in the two chassis's, but wanted one or two opinions from you all.
thanks
-Mike
TA05 spec class.
DF03 w/ carbon chassis
DB01R Stock class
2 x GB01 Tamtechs
Custom solid axle SC
the durga is far superior on the track compared to the df-03. by the time you get a df-03 chassis suitable for the track(i.e. shocks, better diffs, bearing set, slipper and kawada conversion to run 48p gears etc...) you will have already over spent the price it would have taken to get the durga and the slipper kit...
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
Hi Speed,
I've got the new dampers for the durga.. adds a certain ...blinggg.. blinggg... to it..
Seem's to be good but im racing the Durga on indoor carpet. Havent got the chance to try it out on real off-road..
