New motor ideas???
#16
Turns are basically the number of times that a wire is wrapped around each pole of the motor. Ex: A 19 turn motor will have 19 turns of wire around each pole of the motor.
A higher turn motor will have less RPM with more torque. A lower turn motor will have higher RPM with less torque. Basically, the lower the turn motor, the greater your top speed will be assuming the motor is geared correctly.
I would suggest checkpoint motors for brushed motors. Maybe look into the 19 turn checkpoint money motor.
A higher wind motor is like a VTEC engine. There's more power at higher RPMs. A single-wind motor will have more power at lower rpms. If you run on a long track, or you want to go for a speed record, go with a multi-wind motor. On shorter tracks where acceleration is more important, you should stick with a low-wind motor.
#17
If you are looking for custom winds check out www.banzaimotors.com
They sell full CP based motors in any custom wind you want or they will even just sell you a replacement arm for an existing can you have.
They can do anything. I have 12X6, 19X4, 10X1. Just ask! Turn around time is very resonable as well.
