Old 10-25-2007, 11:16 PM   #16
Trader Rating: 26 (96%+)
All you do is wire two cells side by side in series, then you repeat that. Then you 3 wires from one side to the other to double the capacity. One from + to +, one from - to -, and another from battery bar to battery bar. Plug the + and - into your deans plug and use the battery bar one as the balancing plug.
party_wagon is offline   Reply With Quote
Old 10-26-2007, 05:37 AM   #17
Trader Rating: 35 (100%+)
Originally Posted by Bike racer View Post
How's that working out? Can you post some pics?
The lower voltage shouldn't be a concern, just run a 3.5 brushless system.
A guy at our track is running an X-6 with only 4 cells, and a Novak 5.5, and he isn't really hurting for power.
Sure, I'll post some pictures when I get home or this weekend. It is working out pretty good. I don't notice any difference at all vs. the IB3800s I used to run. All I notice is that the buggy is lighter. I added weight to compensate for that though.
The lower voltage is just fine. I didn't even change my velociti 5.5r motor for a lower wind. I geared up from 15t pinion to 18t pinion and it has the same punch and top end it had before with 6 cell IB3800s.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 10-26-2007, 09:06 AM   #18
BuggyKing's Avatar
Trader Rating: 17 (100%+)
What is ur amps on charging lipos?
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 11-06-2007, 10:22 PM   #19
jobo_ph's Avatar
Send a message via Yahoo to jobo_ph Send a message via Skype™ to jobo_ph
Default Thought I'd bump this thread...
There's still no word of any "hard" cased saddle pack lipo coming soon into the market...
Can't anyone manufacture "half" of an Orion Platinum or Carbon (3.7V) that can be connected in series with each other (through 12/14-gauge wire-bullet jumper connectors to get 7.4V) and therefore make the pack useable in both stick and saddle configuration?
Team Associated B4 * T4 * B44
Novak BL * Futaba TX/RX/Servos * Hyperion/Megapower Chargers
Orion/Yuntong/Maxamps Lipo * AMB #6655738
jobo_ph is offline   Reply With Quote
Old 11-06-2007, 10:40 PM   #20
JeromeB's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to JeromeB
eg. An Orion 4800 platinum pack you would charge at 4.8A
JeromeB is offline   Reply With Quote
Trackpower 4800 saddle pack Lipos GSM Storm Australia For Sale/Trade 1 08-26-2008 08:17 PM
trakpower saddle lipos scottk Australia For Sale/Trade 3 08-05-2008 01:52 AM
*** trakpower 4800 saddle lipos *** atomapapa R/C Items: For Sale/Trade 2 07-19-2008 03:05 PM
SEO by vBSEO 3.5.0
