MBX5 is here!!!!
Old 09-05-2005, 10:36 AM
  #556
Jammin'Trey's Avatar
hey, all i have a prospec on the way and wondered what all of the cool mods for this car are? I ran a Jammin' all summmer so i know how to setup a c-hub car.what is a goog setup and geareing for a Rex P5X. (on a looser track)thankx
Jammin'Trey is offline
Old 01-03-2006, 09:48 PM
  #557
devious17's Avatar
Default Front and rear bulkhead loose
Has anyone experienced loose bulkhead screws? meaning due to too many screw in and screw out and the thread is now busted on the bulkheads.
Bulkheads are still in good condition and it'll be a waste to replace them just yet.
Anyone done any salvaging procedure with this kind of problem?
devious17 is offline
Old 01-03-2006, 09:51 PM
  #558
I did notice my rear shock tower becoming loose so I just used a longer screw (replace the ones that are on the bottom hole of the wing mount) and put a nut on the other side of it (near the chassis brace mount).
NismoSkyline17 is offline
Old 01-03-2006, 10:20 PM
  #559
devious17's Avatar
Oops, I didnt make myself clear. My bulks heads are loose from the bottom. The 4 screws holding the bulkheads from the bottom of the chassis is now not holding them firmly.
Old 01-03-2006, 10:37 PM
  #560
At that point it's just something you have to replace.
Old 01-03-2006, 10:38 PM
  #561
devious17's Avatar
hmmmm......I guess I dont have a choice do I? Thanks Nismoskyline17
Old 01-03-2006, 10:41 PM
  #562
Wish someone would make some with metal sleeves molded in them kinda like the warpspeed TC3 diff cases.
Old 01-03-2006, 11:09 PM
  #563
devious17's Avatar
yeah but that would definately affect Mugens Sales of parts
Now that you have mentioned about the sleeve I took a peek at the bulks and found the area surrounding the the screws are not big enough to drill and include a threaded sleeve in it.
maybe CA glue and talcum powder would be a remedy..........
Old 01-04-2006, 03:11 PM
  #564
Davidka's Avatar
Trader Rating: 86 (100%+)
The Mugen gear cases are really inexpensive (most of the Mugen plastic is). I wouldn't chance the repair. The weekend is just too short.
JamminTrey, run your car stock. The only worthwhile hopups I can think of is switching to Craddock or TTR hi-temp brake discs and lighter weight pivot balls for the front end. I am going to change my shocks as the Mugen ones are not hard annodised and the oil turns black pretty fast. TTR shocks fit and are very inexpensive.
Davidka is offline
Old 01-30-2009, 10:03 AM
  #565
Default hey guys on the MBX 5
Hi guys,
This is one of my first post. I'd say most are running the new mbx 6 now. I have the mbx 5 and can't at the moment get the 6.
Has anyone put in the dragon racing titainum drives in their mbx 5. Front and rear.
Here is the deal. I think their undersized just slightly from the bearing their going into, therefore making a little slop in the wheel on its hub. Just looking to see if anyone else has had this problem and how they may have corrected it.
Thanks much for any input
moomaw123 is offline
Old 01-30-2009, 10:06 AM
  #566
Default mbx 5 steering slop
Hey Bros.
Ive got a little slop in the steering linkages on the old muggy and was wondering if a little is acceptable in racing standards. Im new to the sport and I want to win. So just wondering if I should replace the plastic pivot ball caps to reduce slop, or if a little is acceptable.
Thanks guys,
Fred
Old 01-30-2009, 04:30 PM
  #567
TonysScrews's Avatar
Hi Fred,
You dug up a VERY old thread in the Electric Off-road forum. Go back to the General forums and then the Nitro Off-Road forum and there is a huge on-going MBX5/R thread and a MBX6 thread.
edit...
Here ya go Fred: http://www.rctech.net/forum/nitro-of...gen-mbx5r.html
Best regards,
TonysScrews is offline
