Old 09-25-2007, 06:58 PM   #1
Trader Rating: 42 (100%+)
Default tuning suggestions for a T3 ??
I'm back into R/C after 15 yrs out. i have a T3 and it seems to work well on our local outdoor track. If I could have one thing different it would be a little less steering and more rear grip. I have changed the set up several times and here's what i have
green springs all around
#2 piston in front with 30 wt oil
o deg camber
0 deg toe-in
camber link set to shortest distance
rear shocks green springs
#3 pistons with 40 wt oil ( trying to slow the rear susp down to plant the tires)
slightly lower than lever dog bones
middle hole on top shock tower.
GTB with 13.5 26 pinion, 78 spur
Ifmar step pins on back ( worked a little better than bowtie's)
stock front ribs.
the truck is decent until i try the ss 5800 with same set up , except a 20 pinion)
Any suggestions on a better set up for more rear grip . My main issue are seems to be within the first 2 -3 FT of getting going.
I was reading the anti-sqat info, mine is stock, would it help to increase this ?
miket3 is offline   Reply With Quote
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
suggestions wanted for tuning stadium truck (mf2) for asphalt builthatch Electric Off-Road 1 11-29-2006 03:43 PM
beginner questions re: car tuning and motor tuning! Captjono Rookie Zone 5 02-19-2005 11:01 AM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 02:01 AM
Tuning a Motor and 19Turn Spec Suggestions Cain Electric On-Road 25 12-01-2002 05:34 PM
SEO by vBSEO 3.5.0
