Old 08-26-2007, 10:43 PM   #1
Default Some General Car Questions
I got my first 4wd car a little while ago and I had some questions about things that were going wrong any help is appreciated.
1. CVDs, I cant get them to stay tight for anything I tried a little locktight, alot, none, but the pin just keeps coming out and ive had to buy replacements for them
2. Dirt in the Gears, dirt has been getting in the pinion and spur, im not sure if thats normal or not but I usually just let it run and clean it out after the battery is done.
3. The bottom screw of the shock pulls out of the a-arm somtimes, for example if i landed hard off a jump it might strip out and then i have to use a larger screw for the a-arm.
Motoxpro is offline   Reply With Quote
Old 08-26-2007, 10:50 PM   #2
BuggyKing's Avatar
Trader Rating: 17 (100%+)
What 4wd do you have. Some cars have sealed drivetrains like the XX4. Other have open drivetrains like Yokomo MR4-BX. As far as CVD's I use Associated Locktight, never had any issues with the pins coming out.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 08-26-2007, 10:52 PM   #3
I have a BJ4, the main problem has been the cvds though the car is awesome
Old 08-28-2007, 06:01 AM   #4
Jerry P's Avatar
Trader Rating: 44 (100%+)
try using heat shrink on the cvd's.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
Jerry P is offline   Reply With Quote
Old 08-28-2007, 06:13 AM   #5
Trader Rating: 22 (100%+)
convikt is offline   Reply With Quote
Old 08-28-2007, 10:25 AM   #6
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
HPI put out a little tutorial on how to "bulletproof" your CVDs:
Rather than putting Shoe Goo on the pins, I too prefer to put heatshrink instead. Works great on my B4 CVDs, which should be pretty similar to the ones on your BJ4.
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
General MARCCA Questions futureal MARCCA Discussion 108 06-25-2009 08:10 PM
General questions about suspension setup fruitland04 Electric On-Road 8 12-05-2007 09:20 AM
some general questions about 2wd electric beetlebz Electric Off-Road 20 10-11-2004 10:53 PM
General Airbrush use questions tufferwilde Painting, Designs, Graphics and Photography 23 02-16-2003 03:36 PM
SEO by vBSEO 3.5.0
