How important is a schottky diode
I was wondering if anyone knew how important it is to use a schottky diode in a high performance ESC. I want to get one ASAP, but will i damage my ESC if i go without one for a few days.
Most escs will come with a schottky diode. Even if it doesn't, I highly doubt it will damage the esc.
R/C Tech Elite Member
It is really more of a drivers preference if you want to run one or not. Basically using a shotky diode on the motor will increase braking. Depending on the track conditions, I have run up to 4 shotky diodes on my motors. It wont hurt anything if you decide not to run it though.
Great than i'll keep running it without the diode. I was just worried when i put on the brakes that i might damage it after a while.
So don't bother with the diode at all?
A schottky will also help battery regeneration, and so basically you will have a longer run time.
If you dont run a shottky diode you might overheat and damage your brake transistors in your speedo.
If you are running a GM speedo you must use a shottky, if you dont your brake will be gone faaast.. (did it to 2 gm speedos..never again)
crap, i hope i didn't already do any permanant damage. I won't run it untill i get one. Any recomendations on wich one? Novak, reedy
They are all the same, just buy the brand that offers the cheapest diodes...
GM has a stronger type , looks like a transistor. Have never tried it myself, but i have heard that its good (over 2 times stronger than a standard shottky)
where would i get it horizon?
I have no idea...
Just buy a standard shottky and use that, you should be able to get one in any hobbyshop
I thought the same thing until i called four local hobby shops and not one of them carried any. They pretty much deal almost all nitro. No bid deal i'll just get one of tower by novak.
GM v12
