Old 07-23-2007, 07:37 PM   #1
Shark413's Avatar
Trader Rating: 24 (100%+)
Default ESC Fan Protection
I am running fans on both of my two MM ESC's to help keep them running cool. The local track tends to have a layer of small rocks/stones on it and I was worried about rocks getting stuck in the fan. So after some research I found some fan guards that fit the Novak 25mm fans I was was using. They were steel, so they would keep fingers out of harms way as well. After adding the guards I noticed the gaps would still allow small rocks to pass thru so I added a fine plastic mesh (super glued to grill). The grill can be purchased at Master Carr, part #19155K89. Just be sure to attach the guard the right way so it does not hit the fan blades.
I had to squeeze the guard a little to clear all four screws.
Plastic mesh added.
Shark413 is offline   Reply With Quote
Old 07-23-2007, 07:56 PM   #2
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Default b
How did you attach the fan to the ESC and how did you run power to it?
trdsupra88 is offline   Reply With Quote
Old 07-23-2007, 08:09 PM   #3
badassrevo's Avatar
A 4 40 screw will thread into the heat sink fins just like on the Novak GTB. To power it just add a plug and plug it into your receiver.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 07-10-2008, 02:10 PM   #4
Thanks Shark. I had been looking for those covers everywhere. I ordered two today.
turners3215 is offline   Reply With Quote
Air filter protection Edron Nitro Off-Road 10 04-24-2008 07:54 AM
Body protection lanerbrainer205 Nitro Off-Road 13 04-04-2008 10:41 AM
UnderBody Protection? Renuco612 Electric On-Road 8 09-26-2007 03:05 AM
receiver protection for v-one RRR Rayvan Nitro On-Road 7 07-13-2007 04:52 AM
HPI Axle protection? Beholder Nitro On-Road 0 05-15-2004 04:44 PM
SEO by vBSEO 3.5.0
