Brushless Jammin CRT .5 videos
#16
I don't think it is lower. This is a really wide truck (almost square if you look down at it) and lands nicely when jumping. I would say it may even have more clearance and shock travel than some 1/10 trucks.
#19
ARE THOSE ELECTRIC TRUCK PROLINE RIMS OR BUGGY?
#21
I am still waiting for my lipo from maxamps. I ordered it on 7/20 and it still isn't here. I have not ordered from them before. Do they always take that long?
#22
I spent:
$260 for pro version of truck
$180 for Mamba Max
$90 for lipo
$15 for scrap aluminum
$35 for motor mount
$14 for hardened 14t pinion
$120 for servo-you could save some money here.
So if you look at it this way its $700, but you can go to a lesser servo or do what I did and steal the servo, radio, and mamba from a previous car.
$180 for Mamba Max
$90 for lipo
$35 for motor mount
Nice job on that conversion!
What's the pitch of the hardened 14t pinion and where might I source one?
Does that pinion mate with the original spur gear of the CRT.5 Pro?
Enjoyed the video and pics, thanks very much.
#24
http://www.rc-monster.com/gears.php
Use the 5mm pinions because they are hardened, then buy the $5 bore reducer to make it fit on a standard 1/8 motor shaft. 14t is still a little tall for a mamba system. If you use a torquer motor you can play with the gearing a little more, but the mamba probably would work best with a 12-13t. I have seen gearing as high as 20t with a big lehner motor but its kV rating is much lower so you do need higher voltage lipos.
#25
Thanks nitro28
nitro28,
The comprehensive reply to my queries, inclusive of the tips gained from your .5 crt ep conversion experience is much appreciated. Thanks.
#26
Did you make that stearing servo holder? if not how could i get my hands on one? and if not what would be a good servo to go with?
#27
Also what are the temps like with the set up your running?
#28
#29
#30
Ok i just ordered the 7700 because no where has the 6900 and i have a heatsink for the motor with a fan on it and a spair fan i will mount on top of the esc trying to cool down the temps...i will only be running it on 6 cells so it really shouldnt be too much of a problem, do you think?
