Will a Losi XXXT front rim fit on an Assoc. T4?
And have the right offset too. Thanks alot.
Will it fit? yes
Will the offset be correct? no
There is some good info about this on www.rc10t4.com, just do a little looking.
Thanks, found it quickly under "Tips & Tricks". Front XXXT rims are 1/4" narrower each!
Losi XXX Buggy, and Kyosho RB5 buggy do not use bearings in the wheels, the bearings are housed in the hub carrier. Very nice design.
If they did a similar design for trucks, it may be possible to use the same wheel front and rear, eliminating the need for 2 different types of rims (I believe Traxxas does this on their 2wd trucks)
