Old 07-17-2007, 02:32 PM   #46
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Arboleda View Post
I've graphed the voltage under load for my Orion 4800 and Maxamps 6000. I learned two things.
First, while they both start at about the same voltage, the maxamps keeps the voltage higher throughout the discharge. The difference is about .2 volts 1200 mah into the discharge which is arguably significant.
The second thing I learned was that the Maxamps gave far higher capacity than advertised and the opposite was true of the Orion. The Maxamps made it to 6400 mah before dropping below 6.6 volts whereas the Orion lasted 4150 mah before going below 6.6 volts.
Now, my discharge was only 10 amps which you guys will probably all laugh at but that's because I run stock and 19T electric and 10A is a good point between what stock and 19T average. I don't have a means to try more than 10A discharge anyway.
I'd be happy to post the graph if anyone cares to see it and if I can figure out how to export excel charts to JPGs.
I've tried to let these type of data guide my decisions rather than Orions more respectable name, questionable origin of the Maxamps cells, etc.
Having said that, I've had two problems with Maxamps lipos and none with Orion so far. One Maxamps 6000 was left unplugged (I *think* but I'm only about 50% sure) and when I went to use it several weeks later the voltage was down at 4V and I failed to resucitate it. Maxamps sold me a replacement at a discount.
The other problem I had was during an endurance race this past weekend. The Maxamps 6000 lasted somewhere between 30 minutes and 45 minutes per charge in a 1/10th touring car endurance race. We had a Maxamps 6000 and three Orion 4800's that we were rotating in the car during pit stops. Anyway, it was really hot here that day (about 105) and the Maxamps pack had swelled up significantly when we took it out of the car. The Orions did no such thing though there is some breathing room inside their hard cases and if the cells swelled I wouldn't know it. I haven't yet had a chance to cycle the maxamps and see if it's still OK.
So it's possible both of these issues were my fault (I may have left the one plugged into the ESC and running the other for 45 minutes in 105 degree temps may be "bad"). But I sure prefer the performance of the maxamps pack.
Great post thanks. I'm running 6000's to and have had some good luck with them so far. They have been sitting for 2 weeks we'll see how they charge Thursday. Interesting.
UN4RACING is offline   Reply With Quote
Old 07-17-2007, 02:45 PM   #47
i have two maxamp 6000 and it was more than 6700mah
but on my car the vislero was very much power punch 54g less but maxamp have very good run time
and i see the cable is not very good on maxamp need silicon wire
i make spec on both with discharger for calibator at university laval at quebec
discharge 30A
mah vislero 5000 maxamp 6000
250 __7,59 ________7,58
500 __7,51 ________7,48
750 __7,43 ________7,43
1000 _7,37 ________7,38
1250 _7,32 ________7,34
1500 _7,27 _________7,29
1750 _7,22 _________7,26
2000 _7,18 ________7,23
2250 _7,14 _________7,19
2500 _7,12 ________7,17
2750 _7,08 ________7,14
3000 _7,06 ________7,12
3250 _7,04 ________7,1
3500 _7,01 ________7,08
3750 _6,99 ________7,06
4000 _6,96 ________7,04
4250 _6,91 ________7,03
4500 _6,8 _________7,01
4750 _6,4 _________6,99
5000 ___________6,98
5250 ____________ 6,96
5500 ___________6,93
5750 ___________6,9
6000 ___________6,84
6250 ___________6,74
6500 ___________6,5
moy 7,126 _________7,107
60 celsius________ 60 Celsius
274g __________328g
22 X 44 X 135mm ________24 X 45 X 139mm
ironxxx4 is offline   Reply With Quote
Old 10-23-2007, 10:38 PM   #48
Trader Rating: 52 (98%+)
Do I need lipo balancer for my carbon 3200 and platium 4800? Someone at the track told me it will make a difference.
Lots of RC Stuff
straightaway is offline   Reply With Quote
Old 10-24-2007, 06:03 AM   #49
kuzo's Avatar
Send a message via MSN to kuzo
It does not hurt to have one. I don't have the need to balance too much myself. After a full charge you can check each cell with a multimeter and see where the are in relation to each other.
kuzo is offline   Reply With Quote
MAXAMPS LIPO 2100HV 14.8 Brand New - Starter Box Battery Izumi63 R/C Items: For Sale/Trade 6 06-27-2008 06:04 AM
<<< Brand New MaxAmps 4s 6000mah HV Lipo Battery >>> RcOneNitro R/C Items: For Sale/Trade 22 05-05-2008 07:52 PM
Brand new Maxamps 6000mah 7.4V 2S lipo battery pack for sale Cain R/C Items: For Sale/Trade 1 02-08-2008 08:42 AM
MAXAMPS BATTERY REVIEW badassrevo Electric Off-Road 41 10-06-2007 03:12 PM
LiPo MaxAmps Lithium Polymer 4000mah battery kennywiz R/C Items: For Sale/Trade 2 02-03-2007 04:29 PM
SEO by vBSEO 3.5.0
