power surply ??
hey guys
i am having trouble with charging at the track i have 3 chargers piggybacking off of one power surply i would like to make it safe by making a sort of power splitter so that the leads have less risk of touching posituve and negative please i need help asap would like to make it before sunday 7/8 |
its called a power distribution block.
you can buy an integy one or make one from components found in any electronics retailer http://www.rctech.net/forum/showthre...ribution+block |
thanks
i prob should of had a quick search but i didnt know what it was called thanks |
also
if someone could find a site that has instructions about how to make one post it up thanks |
I've got banana type sockects on my PS so I just use banana plugs that can be piggy backed togethers so I can connect more than one device to my PS without interupting anything else that is running at the time. It also leaves my work space both at the track and at home less cluttered and also means its one less thing I have to worry about forgetting when I go to the track.
Hey, if your in a hurry and have a Radio Shack near you, you could buy 3) of these.
Take your time installing them, they work good. The only problem is that when you plug in three of these, it gets very long. |
yer those look a little dangerous if stacked onto of each other
anyone else got a plan i was thinking get a plastic box drill the holes for the posts and connecting all the red and all the black together then connect them to a banana plug or alligator clamp will this work ??? |
I used deans plug and a cheap USB hub from big lots. That was my first distro box. I made a new one out of deans plugs and a plastic box. Cheap and simple.
i made mine this arvo
it works great also i finally brought a power pack only $100 aud for a 20 amp pack at jaycar anyway thanks for the help guys |
