Old 06-25-2007, 11:03 PM   #1
Default Change gearing when using higher powered batteries?
I'm just curious, if you have a 28/83 gear set up, and you want to throw in a 10000 mAh 11.1V LiPo pack; do you have to change the gearing to handle the higher mAh battery packs, or can you run them with the same gearing. The car I'm referrencing is the new Rustler VXL.
I'm also wondering what kind of speed I can achieve with the 28/83 gearing with a 10000 mAh LiPo pack. Any where around 60-70 mph?
Keith_Rogers is offline   Reply With Quote
Old 06-26-2007, 01:59 AM   #2
Trader Rating: 32 (100%+)
You can use same gearing and would get about 50-55 mph with 11.1 volts.
gulio is offline   Reply With Quote
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 11:40 AM
Higher End Servo and ESC Cain R/C Items: Wanted to Buy 0 11-02-2005 09:51 PM
Advantage/Disadvantage of going to higher MaH Batteries noobie Electric On-Road 40 09-02-2005 07:33 AM
Higher end radios brushless Electric On-Road 17 05-16-2005 03:47 PM
How do I change the batteries on the Car? Topes Australian Racing 3 02-17-2003 12:33 AM
SEO by vBSEO 3.5.0
