Best brushless and LiPo for 4wd?
What are the top guys using now for brushless?
I'm buying a BJ4 (original version) and want the best system that won't thermal on me but be as fast as the 9 single I used to run in it.
Suggestions on...
ESC
Motor
LiPo packs
Charger
Suggestions on...
ESC
Motor
LiPo packs
Charger
It's hard to beat the Peak and Orion cells...the soft cells get really beat up against the battery posts when you hit stuff. I have a friend that killed a MaxAmps 6000 cell that way.
The case on my Platinums are squished in, but the cells aren't all the way at the end...2 years and they're still kickin'.
The Duratrax ICE is probably the most economically priced charger and can do everything. I just started using the LRP Pulsar 3 which has Lipo charging capability and works very well. It is probably the best pro level charger available and is extremely easy to use.
This is a good battery.
For $10 more, you can get the better one with the hard case...
http://www2.towerhobbies.com/cgi-bin...?&I=LXLXR6&P=7
Peak does have a brushless motor. But I know longer have anything to do with Peak/Team Orion as an employee or team driver. So you will have to contact them directly for product specifics.
mamba spedo
orion 3200 or 4800 lipos (hard case is good)
orion charger,easy to use,(no thinking)
mamba wont thermal like others but some will say they have no problems.
