gearing for d5 in evader
I have a duratrax evader bx. I just bought a gt7 esc and a d5 modified motor.
Can I just install them without changing the gearing?
Will I need to upgrade the gear box?
Is there anything else I will need to do to make this set up work?
Evader Tranny Info:
Internal Drive Ratio: 2.66
Stock spur: 88T 48p
I think a 20-21T pinion would be a good place to start for the 10-turn Trinity D5.
To make your tranny tougher, I'd recommend you get the following:
* Evader aluminum idler gear (http://www2.towerhobbies.com/cgi-bin...?&I=LXFZP0&P=7)
* B2 diff gear (http://www2.towerhobbies.com/cgi-bin...?&I=LX3224&P=7)
* B2 diff rings (http://www2.towerhobbies.com/cgi-bin...?&I=LX3225&P=7)
* 1 pc. 5x8mm bearing (needed for B2 diff gear)
* Ceramic 3/16" or 2.4mm diff balls
* Ceramic 1/16" thrust balls
Stock spur: 88T 48p
