Old 07-06-2007, 04:58 AM   #46
RURC's Avatar
All sensorless esc can run any brushless motor. Some will do this better than others. Too me the MM dose this better than the others, but the Quark is also very good
RURC is offline   Reply With Quote
Old 07-06-2007, 05:26 AM   #47
Trader Rating: 35 (100%+)
I have tried the Mamba Max with a Novak 5.5r and the motor didn't even spin around. It kind of twitched back and forth and that was it.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 07-06-2007, 05:42 AM   #48
Alltapdout's Avatar
Did you try changing the motor timing @ all? Didn't know if that would help maybe.
Alltapdout is offline   Reply With Quote
question on mamba esc... sixsix1 Micro and Mini Scales 4 06-16-2008 06:49 AM
Mamba 25 question. mashaun Micro and Mini Scales 5 02-22-2008 12:53 AM
Mamba 25 question. mashaun Radio and Electronics 0 02-16-2008 08:06 AM
Soldering Question with Mamba Max biaachmonkie Radio and Electronics 0 01-27-2008 05:39 PM
Mamba Max - Radio Question Shark413 Electric Off-Road 2 06-08-2007 01:51 PM
SEO by vBSEO 3.5.0
