8000mah or 9000mah lipos? questions i have?
i have a new mamba max 5700 system i just put in my rc10t3, and i want to buy 2 lipos a 2s 8000mah or a 2s 9000mah?
I will also run the 2 lipos together makeing it 14.8v for my (in the makeing) brushless losi 8ight T so the lipo batterys will be doing double duty for awhile till i save up more money.....
all the racers at the track have to add weight around 2-3oz's an thats with the 2s 8000mah lipo, an the 2s 9000mah is 2-2.3oz's heavyer so since im moddifying my t3 for lipos ,the 2s 9000mah is only slity bigger an i dont have to add weight to the t3, plus itll have longer runtimes,only thing thats shying me away is it says 20C Constant(120 amps)
30C Sustained(180 amps)
50C Burst(300 amps)
, an the 2s 8000mah says 20C Constant(160 amps)
30C Sustained(240 amps)
50C Burst(400 amps)
will this matter?
also when i run 2 together for my Bushless losi 8ight T will that stuff matter?remeber the 8ight T will be 9-10lb's
btw there maxx amps batteries....
50C Burst(300 amps)
50C Burst(400 amps)
will this matter?
50C Burst(300 amps)
50C Burst(400 amps)
will this matter?
50C Burst(300 amps)
50C Burst(400 amps)
will this matter?
That print is correct. You multiplay the c times the ah to find the current. A 20 c discharge on a 6ah pack would deliver 120 amps of current.
I hope you don't think the packs can take 180 amps. Check out the rpm on the 5700 with 4S too.
