Old 06-05-2007, 09:48 AM   #1
slufoot78's Avatar
Trader Rating: 60 (100%+)
Default Transponder, replacing wires???
Hello, I have a transponder that the wires are bare in several places, I heat shrinked them but would really like to install new wires. Has anyone out there replaced the wires before or will I need to send it in to get them replaced? Is it a glued case or can it be opened without busting it. Thanks for any info and everyone have a wonderful week... Patrick
slufoot78 is offline   Reply With Quote
Old 06-05-2007, 10:12 AM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
you can send it in to amb and they will repair, and test it for a small fee, its worth it cause its done right...
Jason Halvorson is offline   Reply With Quote
Old 06-05-2007, 10:27 AM   #3
Scrubb's Avatar
The case is glued together, your best bet is to send it to amb for repair.
I have CAREFULLY cut the end off the case, and very carefully replaced the wire inside the case (not much room to work with) and glued the case end back on. But it takes lots of skill and patience. I wouldn't recommend most people try it. There is another thread on RCTech about replacement transponders (i-PT, I think) for a good deal.
Scrubb is offline   Reply With Quote
Old 06-06-2007, 07:24 AM   #4
gndprx's Avatar
Trader Rating: 18 (100%+)
Definately not a fun job. I had a PT come loose on me and get wrapped in the rear wheel...pulled the wires right out of the case.
I ended up cutting the case open and had to grind down the material that they use to coat the board so I could get to the wires and solder new ones to what was left of the old ones. I then re-coated the entire assembly glued the case back together.
I absolutely do NOT RECOMEND this. Frankly I'm amazed that it even still works, but so far it's been okay.
My suggestion is as above, get one of the new transponders that can clone your ID before risking killing it completely.
gndprx is offline   Reply With Quote
Old 06-06-2007, 11:12 AM   #5
BuggyKing's Avatar
Trader Rating: 17 (100%+)
i wouldn't touch the wiring just send it in for repairs. They will be able to fix it for you.
BuggyKing is offline   Reply With Quote
Old 06-06-2007, 11:39 AM   #6
Hi, at MRT we offer a repair service for PT's. Often we replace the lead when a broken PT is sent to us to have a clone i-PT made. The lead replacement involves the case being opened and a new lead being fitted, the case is then resealed. The case ends up being back to its original condition, ie if it's a new looking case it will hardly notice that the repair work has been done.
The i-PT info/form is at www.rclaps.com and the i-PT thread is here:
New Improved Personal Transponder (i-PT)
We also have a new 'stealth' PT (1/2 the size of the AMB PT) due out, the thread is here:
Stealth PT - New PTX Personal Transponder
Terry_S is offline   Reply With Quote
Replacing wires on LRP v7.1? SammyZ Radio and Electronics 2 08-25-2008 05:56 PM
replacing a tail fin gillandro Nitro Off-Road 0 04-23-2008 03:40 AM
REPLACING BEARINGS casimirsa Onroad Nitro Engine Zone 12 05-20-2007 08:36 PM
Replacing SH .28 but with what glyn Monster Trucks 2 02-20-2007 06:53 AM
GT7 replacing TC2 & TC? XER987 Electric On-Road 3 11-26-2002 02:58 AM
SEO by vBSEO 3.5.0
