Old 06-04-2007, 01:40 AM   #1
Default help. esc hoter than batery.
hey i recenlty purchased a tl-01b(baja king) copy of ebay. its actually quite good built very strong and prety quik with even the stok motor. it came pre built with all the electronics and that but on my esc wer the lil heat give of thing is well my battery gets hoter than that does so does that mean that my esc is rooted casue it cant handle the battery or sumthin and it wont let of the heat of the battery through that?
rmboi93 is offline   Reply With Quote
Old 06-06-2007, 10:05 AM   #2
Hi, are you running full throttle or doing little throttling every now and then?
The ESC is a gate that control current to the motor. It has FET ( Field Effect Transistor ) It controls the current to the motor. Lets get simple.
When you full throttle, you are opening the gate wide, so maximum current pass through. The problem come when you throttle a say 25 to 50 percent only. So in theory, you only open the gate about half. Right? So, what about the other half?
It it wasted as heat. That why the FET heat up. So to play save, try not to half throttle longer than necessary. Anyway, these kit are meant to run fast.
boatman is offline   Reply With Quote
Old 06-06-2007, 10:18 AM   #3
badassrevo's Avatar
its is normal,
badassrevo is offline   Reply With Quote
Old 06-06-2007, 11:10 AM   #4
BuggyKing's Avatar
Trader Rating: 17 (100%+)
How is the gearing on the motor. This will cause the speed control to run warm. It may even thermal if it gets hot enough.
BuggyKing is offline   Reply With Quote
Old 06-07-2007, 03:37 AM   #5
hey guys its not the esc thats geting hot its my batery thats geting quite warm and i thought the esc is spose 2 give of that heat?
what motor and batery for my mini t mini t lover Micro and Mini Scales 8 09-03-2007 09:24 AM
new batery / motor sale snopro31 R/C Items: For Sale/Trade 2 07-29-2007 02:12 PM
WTB batery cases FastFat R/C Items: Wanted to Buy 1 02-08-2007 08:04 AM
How you dispose your old batteries/ batery packs Car Breaker Electric On-Road 15 06-01-2006 06:53 PM
Integy batery zapper EFC321 Rookie Zone 4 06-19-2005 08:13 AM
SEO by vBSEO 3.5.0
