Old 05-31-2007, 05:15 AM   #1
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Default JP FX21B-8T
Im geting one of these engines and would like anyones opinion likes, dislike's, preformance, fuel Consumption, how easy to tune
Technical Data FX 21 B-8TC. Capacity :3,49 ccBore :16,26 mmStroke :16,80 mmPorts :8 + 2 By passCrankshaft :ř 14 mmCarburetor :ř 8 mm + reducerGlow Plugs :TurboWeight :385 gr# FX 21 B-8T
Turbo Glow Plug
Turbo Glow Plug for best performances.
8 ports ABC Sleeve
This 8 ports sleeve is revolutionary in the Off-Road engine’s range. The exhaust has two boosters in order to increase performances and manage the fuel consuption on the best.
The last generation conrod is lightened with 2 bushings. The piston is also pierced to decrease the piston temp.
Turbo Crankshaft
The modified and lightened crankshaft is filled with the special red putty which is positionned to improve the gas passage. In order to reduce the friction and the wear, the crankshaft is HardBlack coated.
The Turbo design of the crankshaft's head highly improves the engine power. For best performances !
The special Off-Road carb is made of plastic in order to avoid the «vapor-lock». As all FX Engines, it has a simple adjustment (1 screw). The adjustment is easier
Nitro$junkie is offline   Reply With Quote
Old 05-31-2007, 06:14 AM   #2
I might be wrong but its a tuned version of a novarossi 421b.
CRT.5 SH .12,
damo666 is offline   Reply With Quote
Old 05-31-2007, 03:20 PM   #3
mremtr's Avatar
It's not a true 421,because it only has 4 head bolts BUT I will tell you this:
That is one incredlbely powerful engine ! but it is not the best on fuel , 6-7 minutes ,super bottom and mid range, after mod from RB mods it will be super smooth on the bottom with incredbley powerful mid and top! Best pipe for it is a 9886 with medium long to long header . I have 2 421's at my track and both of them are total animals ! And can beat up on C6's with ease. I have only seen 1 other engine that can run with them as far as speed and power and that was a JPmod V-Spec.
mremtr is offline   Reply With Quote
JP FX21B-8T Nitro$junkie Onroad Nitro Engine Zone 31 06-08-2007 01:59 AM
JP FX21B-N 5P BUGGY STANDARD MODIFIED Engine for sale matirx_mimi R/C Items: For Sale/Trade 3 04-23-2005 02:16 PM
SEO by vBSEO 3.5.0
