Old 05-11-2007, 06:07 PM   #1
acsubie's Avatar
Default Engine break-in ?
have a question guys, got a new engine,for my crt .5,im in the break-in stages running very rich(plenty of blue smoke), linkages are set correctly, idle screw is set(very minimal gap)...heres my problem, the truck still wants to engage when its suppose to be still and its not even at a slow crawl, its at slow cruising speeds..is this because the car is running soo rich? or what else can be causing this, the clutch? i thought maybe the throttle/brake servo was glitching but i even removed the air filter and the carb slide isnt even moving yet the tires are moving quickly...any help would be aprreciated guys, thanks
acsubie is offline   Reply With Quote
Old 05-11-2007, 07:24 PM   #2
anyway to adjust the idle?
Mugen MBX5R - retired
SC-10.2 Avid Hobbywing Stock Spec Speed Passion
B4.1 SpeedPassion Reventon R 17.5
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Old 05-11-2007, 07:40 PM   #3
acsubie's Avatar
idle needle is still in stock setting with very very small gap...im still leaning toward the clutch being the problem, but its a brand new clutch setup, could it really have gone bad with less than 10 tanks thru it
Old 05-11-2007, 07:42 PM   #4
FrankBlack's Avatar
That is usually a sign your clutch bell bearings are gone and or the clutch springs. Ofcource a very high idle will do the same but im sure it will be one of the above.
FrankBlack is offline   Reply With Quote
How not to break in an engine ! Maximo Nitro Off-Road 4 08-05-2008 09:34 PM
engine break in 37 RACING Nitro Off-Road 10 03-15-2008 02:25 PM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 03:08 AM
RB V12 engine break in help alucard13 Nitro On-Road 7 08-31-2003 08:34 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
SEO by vBSEO 3.5.0
