Old 05-08-2007, 10:41 PM   #1
Default electric rustler some questions
1. I read about aluminum idler gear but still not sure what it really does, and where do you install that part? (between spur and pinion gear??)
2. I'm getting mamba system soon, probably 5700 or 7700, what is a good gear ratio so it does wheelie easily and have good speed run? (I am thinking 12/90, but if you have better idea please tell.) and which site is selling it for cheap?
qdv is offline   Reply With Quote
Old 05-09-2007, 08:04 AM   #2
padailey's Avatar
1. The idler is inside the transmission housing. Inside it is the middle of the three gears. The larger is the diff, and the top gear is attached to the slipper shaft only inside the case. If you are going to use the aluminum idler I would recommend you also go with the delrin top gear. The aluminum will more easily get chewed up by the stock steel top gear. Part #'s I think are 1996X and 3195X.
2. Can't help much with gearing.... I run a 12T brushed motor geared at 18/87 I think. As far as Mamba goes the cheapest price I've seen is at Bishop Power Products http://www.b-p-p.com/products.php?cat=40. I don't know anything about the place but prices look pretty good with free shipping.
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 05-30-2007, 10:34 AM   #3
ERustler's Avatar
Send a message via AIM to ERustler
i got the 77. and i go 40 with just a 2400 mah nicad. it doesent wheelie, but install program, and up it and it will wheelie. i want to change gearing, too but i dont know what to go to either.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
There is no such thing as budget RC.
ERustler is offline   Reply With Quote
Old 05-30-2007, 11:38 AM   #4
The thing about 7700 is that it only seem to like 15/90 gearing, lower or higher will heat it up a little quicker. What I"m doing now is do everything necessary to keep the heat as low as possible (maybe lots of those integy high speed fans) and bump up the setting in mamba. So far I applied a thermal heat sink, 1 heat sink with 2 fans, 1 fan for esc and it stay cooled after 2 fresh batteries, the 3rd battery will heat the motor up.
Traxxas Rustler XL-5 Questions - Please Reply kashif Electric Off-Road 16 07-11-2008 03:38 PM
Rustler ESC related questions karim18 Electric Off-Road 3 08-12-2007 08:59 PM
A couple of Rustler/Nitro Sport Questions, TRX3.3 engine?? bellr77 Electric Off-Road 6 04-24-2007 05:18 PM
Electric Rustler cnitro R/C Items: For Sale/Trade 1 04-06-2004 05:39 AM
Traxxas Rustler Questions... Rustler8uagn Electric Off-Road 4 12-01-2003 04:37 PM
SEO by vBSEO 3.5.0
