mamba max brushless systems
hi,
wich is the best mamba max brushless system?
also wich is better? novak 7.5 brushless system or the best mamba max? if so how much difference
What's best is like a Chevy vs. Ford debate....
If you are looking at the Novak 7.5.... the Mamba 4600 is probably the closest to that.
IMO the Mambas have more power... if you want low end torque esp. They have a stupid amount of rip. But the LRP and Novak are great for racing because they don't have as much bottom end. It's like running a brushed single wind vs. a triple... the higher winds are smooth and easier to drive. Just depends on what you like and what you are doing with it.
i have the mamba 5700kv in my zx-5 witch i just finished
im going to run lipo's
now for the 1st time in rc
im very afraid
im very afraid
ok thanks the mamba max 7700kv is the fastest?
yeah.. the 7700 is the fastest.... wicked fast.
Tech Legend
the 7700 is the fastest using 6 cell power. If you can go beyond that, the 5700 I believe is the fastest. The 7700 is rated for 6 cell use only.
Keep in mind, have seen plenty of people getting rid of 7700 units as being too fast and can't control them. You may want something slower to start with. You can always upgrade the motor later.
I have the 5700 unit and its stupid fast on 6 cells. Can blow by the 1/8 scale nitros no prob on medium sized tracks.
Tech Legend
mambas have lipos in mind, they have cutoffs in them specifically for lipos or you can just set the volts for whatever. They can take I believe 11.1V lipos, maybe more. So they can be used for more than 6 cells.
The cool thing about the USB is that it allows you to fully configure your ESC. You can set it anyway you want.
Only knocks on my mamba max so far:
Size
position of USB port (should have been on top of ESC instead of from the side, limits mounting locations)
Non-solderable wires for motor
5V BEC
Size
5V BEC
I run the Mamba 4600, and I also have a Novak GTB 6.5 setup in my other car...I agree, the Mamba has much more torque and punch than the Novak, and both have very similar top end (I am running 6 cell packs).
I beleive the Mamba speedo can take more voltage, unlike the Novak. Best to check the Castle Creations site for specs on it though.
a 5700 would be fine in a 4wd buggy
Sweet, is there a recommend gearing somewhere?
Also, I just found their site and on there it says 'NOTE: Mamba Max 6900 & 7700 motors are limited to 8 cell NiMh/9.6 volt or 2 cell/7.4 volt lipo battery packs!'.
Does this mean I can only use 8 cells or 8 cells is the highest I can go?
Cheers
Cheers
