Old 04-10-2003, 02:14 PM   #1
Help needed with linkage setup
I'm setting up my throttle/brake linkage. I don't know if this is how it should look like but the spring is compressed all the way when I apply the brake and the horn is parallel with the servo(see pic 1). The horn moves about 10mm from idle positon to full brake. That seems too little for me. But it can't go any further because there isn't any room between the spring and the collar.
What am I doing wrong?
Full brake...
Full throttle...
NitroMaxx is offline   Reply With Quote
Old 04-10-2003, 08:09 PM   #2
Randy Caster's Avatar
Trader Rating: 45 (100%+)
The only real thing I see wrong is at idle, the collar is not against the horn, so it has to move a hair before your throttle engages. You might want to turn down the braking throw a little bit too, or take that collar off the spring next to the carb, and just let the spring sit on the ball end if it's long enough.
throttle/break linkage setup gflyer_22040 Nitro Off-Road 5 05-05-2008 08:53 AM
Throttle/Brake Linkage Setup dsl Electric Off-Road 1 04-17-2007 01:36 PM
CE Turbo 35 GFX Help Needed for Setup gunlocators Electric On-Road 5 04-07-2007 11:17 AM
Help needed for GM V8 esc setup jawa Electric On-Road 3 07-31-2006 01:05 PM
setup board needed ntc3freak R/C Items: Wanted to Buy 0 10-08-2004 03:54 AM
SEO by vBSEO 3.5.0
