Old 05-03-2007, 04:37 PM   #1
aN4rK1's Avatar
Default Buggy Steering Question
I own a sportwerks turmoil, and I was at our local track yesturday. At first, It was running good, had a few oversteer problems at first, but i fixed that. Later on, it suddently stopped steering at all. So I brought it in to check. I changed the rx pack thinking it was the batts but it was the same. I thought that my servo was stripped, so I checked that, but it wasnt.
My servo is weak ill admit it, only 90 oz of torque, but it was fine before. Either way, i ordered a new servo. This one:
This one should be more enough now right?
I wanted to check it further today. So I took apart the front suspension and drivetrain. I isolated the tightness to two screws on the steering ankerman rack. Pic:
(two silver screws that connect the blue ankerman to the servo savers)
I found if i unscrewd the screws a bit it steered MUCH more easily. But if I leave them unscrewd they will come off right? I cleaned the buggy and tighted the screws, it seems to be like it was before the incident yesturday. So what should I do? Leave it tight and let the new servo take care or of it? Or should I loosen and if so, how do I make sure the screws dont fall out?
aN4rK1 is offline   Reply With Quote
Old 05-03-2007, 05:10 PM   #2
pirate60's Avatar
Trader Rating: 15 (100%+)
Your steering must be bind-free!
If you have to back off on some screws, use blue loctite to ensure they stay in there.
pirate60 is offline   Reply With Quote
Old 05-03-2007, 05:56 PM   #3
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Make sure your steering linkage isn't binding. Keep it clean from dirt etc.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 05-03-2007, 06:58 PM   #4
aN4rK1's Avatar
Define bind free, the motion is very smooth, its just tight. And should it loose enough so that it will be able to turn with almost little to no force?
Old 05-03-2007, 09:13 PM   #5
gubbs3's Avatar
Little to no force. Just like a suspension arm should swing free when the shock is disconnected. Great choice on the Airtronics servo!
gubbs3 is offline   Reply With Quote
Old 05-04-2007, 09:14 AM   #6
aN4rK1's Avatar
Got her fixed, MUCH better now. Thanks guys!
XXX-CR Steering Question WHOBEE Electric Off-Road 6 09-03-2008 05:46 PM
Steering servo question j0ej0eTMAXX Rookie Zone 12 03-21-2006 12:12 PM
steering knuckle question onroad dude Monster Trucks 0 02-04-2006 11:36 AM
Steering Question Michael Barch Electric On-Road 11 12-23-2005 02:00 PM
TC Steering Servo Question... squarehead Electric On-Road 7 01-14-2004 07:08 AM
SEO by vBSEO 3.5.0
