What Clutch Shoe are better ? for .21 engine off road
Let me know your point of view about that.
There is no one "best" choice. Aluminum shoes can vary in their grip levels. They also require more maintenance. The regular composite shoes don't grip as much but need much less maintenance. It all depends on the track you're running on and how much maintenance you're willing to do. I prefer clutch springs and aluminum shoes from M2C. https://www.m2cracing.com/
Lots of people also like the Fioroni sliding clutch. I also like the CRF V6 Adjustable clutch. There's also the RMV Speed 2 and Speed 3 clutch systems. So many choices!
regards
speed metal
regards
speed metal
the werks clutch is king. Unless you like to buy lots of high dollar shoes and like taking them on and off.
Originally Posted by weaponx
You can also run a combination of aluminum and carbon shoes. I run 2 carbon and one aluminum with good results.
I noticed some clutches have Teflon shoes as options. Has anyone ever run those? I know they'd hit a little less because they'd slip a little but wouldn't they wear insanely fast? Plus, Teflon cold flows. It would seem to me that the tolerances could be way off because of that.
clutch
My experience with the werks clutch is not very good. I tried to run one several times and everytime it seemed to make the engine run hotter than with a standard clutch. I would run the engine with the werks clutch and then run it with a standard clutch and it would be about 20 degrees hotter without touching anything else. In my opinion if you do not want to spend the money running aluminum shoes all the time buy a Firoini clutch. It last forever and does not sacrifice performance. I run the firoini turbo slider with carbon shoes and two springs on all of my club race motors, because it does not require ant maint. On all of my race motors I run 3 aluminum with 1.0 springs. I hope this helps John.
Kingheadz makes some very nice shoes for all brands. I have some pictures on our online store. The 7075's last forever. Go and take a look.
i just tried using 2 aluminum(ofna) and 1 carbon(mugen). seems to be working very well thus far. will update after another few outings.
Jmnay_83 - My experience with the werks clutch is not very good. I tried to run one several times and everytime it seemed to make the engine run hotter than with a standard clutch.
You must not have had it set correctly. All of our engines run the same temps. We have 6 - 8 of these clutches on our track and all of them run really well.
We run Rulon/Carbon combinations on our stuff.
Engines will overheat if you let them slip too much. That is with any clutch.
The Works clutch does rule. I have also been running a lot of the Losi clutch.
Both are very good when setup right.
I have also been impressed with the Kyosho with all carbon and 1.0 springs.
Very easy and no maintenance for a whole season. No probs with slippage either. All are on the expensive side but well worth it.
Run the Works with Rulon and find out why every onroad racer runs it as well.
TEX
TEX
