Old 07-13-2008, 11:00 AM   #16
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Default 8
I had 3 G+'s and never had luck putting power to them. I tried MM 5700's, then tried 4600's and both of them tore these cars up from the start. IMO, the b44 or other modern shaft driven 4wd is the way to go if you are interested in putting down a ton of power...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 07-13-2008, 11:28 AM   #17
Originally Posted by K_King View Post
Why? Most tracks you cant even put that power down, and its not a truck.
Too many people just want to go get the fastest, then wonder why they cant control it.
If you have to ask, it's more likely going to be a case of too much motor for you than it's going to be an issue for the car.
rocket-mtrsprts is offline   Reply With Quote
Old 07-13-2008, 01:32 PM   #18
Registered User
Originally Posted by george_georgoul View Post
I was palnning on getting a lossi XXX-4
I wanted to put a serious motor in it. 10 turn would be the minimum
Can I put 8 turn motor in or will the gearbox die.
Can this truck handle serious motors?
It will handle the power no probs, just dont hit anything!!!
Loop&Roll is offline   Reply With Quote
Old 07-14-2008, 01:53 PM   #19
JeromeK99's Avatar
Default XXX-4 and fast motors
The XXX-4 can handle just about any motor out there.. I've run 9t brushed and even a 3.5 brushless (insane!).
Just make sure it's not all blown out.. you need to be running the upgraded yellow belt (if you have the older version).. diffs should be in good condition.. and most important is the slipper.. make sure it is tight enough.. 1 run with it too loose and it's shot! Once you glaze the little pads.. they are done!
So be sure to test it before you run a whole pack!
JeromeK99 is offline   Reply With Quote
hopped up xxx4 G+ with 2 19T motors jsmax R/C Items: For Sale/Trade 3 12-07-2006 06:50 PM
lossi-ofna mart1968 R/C Items: Wanted to Buy 0 03-16-2006 05:43 PM
Francis & Kinwald(lots of Trinity Blue) XXX4, TC3, Motors, Batts, etc. teamlosi27 R/C Items: For Sale/Trade 5 10-17-2004 11:46 AM
FS/FT brushless, xxx4, twinforce, losi stuff evx motors pcnutz R/C Items: For Sale/Trade 24 10-14-2004 10:27 PM
Lossi xxx-nt F/S Caesarsalad R/C Items: For Sale/Trade 4 12-07-2002 11:14 AM
SEO by vBSEO 3.5.0
