What engine is this? (pics)
It says Hyper .21 Turbo on the top of it
Cant find it here...http://www.ofna.com/engines.html
Anyone any ideas what it is? 4 port? 8 port? spec?
Thanks in advance
the top looks silver on the ofna site and no writing on the top
is there much difference in performance between the .21 hyper motors anyway? 1.9hp to 2.5hp...cant be that much in it?
It looks black to me, and they change things so often, who knows. It could be an older version. I've only had experience with the hyper .21 8 port. (Purple head.) While some complained, I never had a problem. I'd put another one in a buggy anyday.
That one looks to be on their cheaper side, so I'd guess not as many ports. Not sure if your racing or bashing. If it has good compression and runs good, run it. For bashing, it should move that buggy around just fine.
It may be the 8 port. If you buy the 8 port from the shop - it has purple head, but if you get it in your rtr buggy - it has a black head. The best way to know exactly is to count the ports yourself The only problem is that you'll have to get the head off.
